graph,
You could also apply Stroke>Dashes to the offset white stroke/nofill path (stroke equalling the dot diameter, using Dash = 0, Gap = (approximate) distance, and Round Cap.
If you have less than CS6, you may also apply the free Adjust Dashes script for an accurate even distribution (of the dashes/dots); it is available here:
Thanks.
-Do you have to create the scatter brush, or is that a default?
-Also, how do you enable it so that scatter brush can be selected for the stroke (like you have an additional dropdown to the right of the stroke dropdown where you can see it says the word "Scatter."
If you don't mind my asking, how do you do the same effect with a regular white line stroke (again with some space from the edge)? I tried playing with adding an inner stroke from the appearance palette and then another fill on top but that didn't work.
Thanks!
North America
Asia Pacific
