How do you search or filter by resolution?
In Find you can search for any metadata that is recorded. But resolution is really not a good parameter to measure picture quality, if that is what you are after.
The quality is set by the number of pixels in the image. So a picture with 3800 x 2600 pixels at 300 ppi is a far better picutre than one at 1200 x 780 at 300 ppi.
In fact the 3800 x 2600 image at 100 ppi is still better than 1200 x 780 at 300 ppi. (Work this out for yourself in PS Image/Image Size by changing resoluton and watch numbers).
And if you send image over the web they actually strip out the resolution so it is just pixels (height x width).
Resolution is what I want. I have scanned images with different resolutions.
That is not possible nor to my opinion very useful. A resolution is just a number, no more no less.
As an example, I have a file from my dSLR that has 5184 x 3456 pixels at a resolution of 300 ppi
The dimension then are 17,28 x 11,52 inches.
When I change the resolution to 240 ppi (without resampling it because that is a different matter that should be carefully executed) then my dimensions have changed to 21,6 x 14,4 inches but my pixel dimension still is 5184 x 3456.
And it is pixel dimension you have to search for.
You can add extra criteria so if you want files that have 2000 pixels or less then choose dimension and fill in less or equal 2000 and you get all the files smaller then that.
Might be needing an extra calculation to rule out portrait and landscape differences but you can do so with adding an extra criteria.
If you need all your files for what ever reason to be on 300 ppi then create an action in PS. Open 1 file and start a new action to record. Choose menu image / image size and change the resolution to 300 and be sure to have unchecked the resample image option (because that would change the dimensions and the file size and you don't want that in an automated process for different sizes.
Hit OK and maybe even include a Save As command (don't change the filename otherwise they overwrite each other with the same name) in a new location to leave your originals untouched and hit close and stop the recording.
Then in Bridge select the files you want to change, go to the menu tools / photoshop / batch and choose your new created action. Hit run and all the files will be set to 300 ppi.
But it is just a number that without the pixel dimensions has no meaning at all.
It is very popular for clients to ask for 300 ppi but if you send them a post stamp size at 300 ppi the can't make a nice print out of it.
Thanks guys, I know all about dimensions and resolution.
For me in this project it would be very useful to use resolution.
The images are from a scanner + plus some cropping in PS. So the number of pixels in the images vary a lot, as you can see below.
In this case resolution is crucial. Images from a camera is of course different thing.
Here are some of the files. I have inserted the resolution in the name of the file.
Still not fully understand what you are looking precisely for.
If you already have added resolution in the filename (at least I understand you have mainly two resolutions with the addition of minus and plus. You only need to choose 4800 in the quick search field to have a start and then as Paul already stated use the sort order option in the path bar and choose resolution to have a sort order.
You can fine tune with the filter panel using orientation and aspect ratio. Or select a couple of files and with the selection use an other sort order for dimensions or even use this selection in a collection to have a better oversight.
Maybe you can clarify a bit more how you would have them sorted if the above is not the goal you are looking for.
What I am looking for is clearly written in post #1: "How do you search or filter by resolution?"
It would be nice if you could choose resolution (or any metadata) in Filter. I use Filter a lot and found it very useful. With scanned images you can regard resolution as a kind of "focal length".
It seems that Find with All Metadata is the closest that is available now. It is not 100% what I was looking for (for example it will show also 1200 pixels if you search 1200 ppi), but used with care, it is seems to be quite useful. Thx for the tip Curt!
Since Filter has only a limited amount of categories you would have to be creative to use Filter to get what you want. Also it only filters the images in the current folder so this is a restriction if you want all images of a certain resolution.
Suggestion: make your own code for a keyword to represent resolution. Filter works well on keywords. You could use the Search to bring up the images by resolution and then keyword them.
In addition, if you have them keyworded to resolution you can then use Search if you want to look outside of the present folder.
But think what you really want to achieve for obtaining images with a certain resolution. As Omke and I have pointed out resolution is really a non-event as it is a variable that just dictates how many pixels per inch are printed to the screen. If you are interested in the quality of the picture you need to concentrate on the pixel dimenstion. As I pointed out an image at 3800 x 2600 pixels at 100 ppi is a better picutre than one at 1200 x 780 at 300 ppi. Here is a link to add to the issue http://www.steves-digicams.com/knowledge-center/coming-to-terms-with-d pi-ppi-and-size.html
This is not intended to tell you what to do as we have no idea of your needs and knowledge of the issues.
And of course in the Sort options on right side of toolbar once can sort by resoultion, file size, dimenstions, etc.
I have to try your suggestion using keywords, thx for the tip.
I have used Sort. It kind of helps, but it is not the same as Filter, of course.
But, you still dont get my problem. With SCANNING (in my case old negatives) RESOLUTION is not a non-event. On the contrary, its is one of the most important and crucial decisions you make in scanning. If you scan a negative with 300ppi or 2400ppi, the result and quality is different. After scanning I often crop the image. The amount cropped varies a lot depending on the image.
Here is data from two images, both scanned with 1600 and 2400 ppi. The negatives were same size, but I have cropped Image A a bit more. In real life there are a lot more images and several resolution.
| Image A 2096 x 2096 | 1600 ppi |
| Image B 2107 x 2107 | 1600 ppi |
| Image A 3146 x 3146 | 2400 ppi |
| Image B 3156 x 3156 | 2400 ppi |
The problem is to easily filter/search/find the 2400 ppi scans from the rest. As I wrote in my previous post, your suggestion of using Find with All Metadata seems to be best method available.
PS. But if we talk about images from a camera, resolution is of course totally different thing. I usually dont care about the resolution at all. I look at the number of pixels. As you and Omke pointed out.
Well, here it becomes a bit tricky because I have not scanned for a long time but basically to my opinion it is the same principle. If you scan a negative at 300 ppi it creates a much smaller file then when you do so at 2400 ppi but this still only reflects the width and height because your original (from slr) is only 24 x 36 mm and the higher the ppi setting in the scanner the more data it will create for details.
That said, just try a scanned file and change the ppi in PS Image size to 300 ppi and be sure to deselect the resample option and the result should be still a file from the given pixels at the start. So I still think image size is the correct sorting option for you :-)
I agree with the above. When you scan film you can specify the number of samples it takes per unit length of film scanned. If you scan a 1 inch by 2 inch piece of film at 300 ppi, you will get an image that has 300 pixels by 600 pixels. If you scan the same film at 2400ppi you will get an image that has 2400 pixels by 4800 pixels. The number of pixels in the scanned image is the length of film scanned multiplied by the ppi selected for the scan. When you scan film you can change the resolution for the scan.
Images from a digital camera have a fixed resolution that is determined by the image sensor, you can only change this by purchasing a different camera.
If you scanned the same size film at two different resolutions you can identify these by the difference in the number of pixels in either direction or the file size unless you saved as jpg at different compressions for the two scans.
North America
Asia Pacific
