qdalton
Converting my flash intro
Feb 11, 2013 6:58 AM
I just downloaded my first trial version of flash. I do not really know a whole lot about the way everything works but I've been trying to learn as I go. I have created a small intro that I would like to play at the start of my youtube videos, I'm not real sure how to do this, can someone offer some help or advice as to how I need to save or convert and then use the intro to tie them both together? Thanks!!
  • kglad
    Jul 21, 2002
    Feb 11, 2013 5:53 PM   in reply to qdalton
    are you publishing for as2 or as3?
  • kglad
    Jul 21, 2002
    Feb 11, 2013 8:51 PM   in reply to qdalton
    using cs3, you could add the following to the last frame of your intro:
    navigateToURL(new URLReqeust("www.youtube.com/youryoutubeid"));
    Feb 12, 2013 1:01 AM   in reply to qdalton
    Youtube doesn`t accept swf files to upload, you have to convert your animation to a videofile.
    There are different options here:
    1.If your animation file contains no actioscript and no nested movieclips you can directly export from flash to video
    File>Export>Export Movie>Quicktime
    2.If you want to use a video programm like Premiere/After Effects to composite your intro manually with your video files
    File>Export>Export Movie>PNG Sequence (Best Quality, Alpha Channel can be kept)
    3.If your source files contains Actionscript or interactivity, you need to look into 3dParty products like this
    Feb 12, 2013 5:36 AM   in reply to qdalton
    After effects is fine.
    Feb 12, 2013 5:53 AM   in reply to qdalton
    Just append any new questions to this thread, the chance of quick response is much better and a solution -if found- is helpful for the whole community.
