When I double click an AI file to open it, I get this message: "Can't open the illustration. There is not enough room for the window, increase document area and try again". This error started happening about a week or two ago. Although it is inconvenient to have to go to File>Open and then locate the file to open it since I am used to doing it the other way at least it is a way to open the AI file. I just discoved that if I double click a graphic in a Adobe Acrobat Pro using the Edit Object I get the same error message. This is a problem.
I have checked previous discussions about this and tried things like unchecking the "open as tab" option in the preferences but that does not work.
I would appreciate any other suggestions since this is very annoying.
Jane
Creative Suite CS6
WindowsXP
Are the error messages coming up in the correct application? i.e. when you double click an .ai file is it actually Illustrator that is supplying the error message or could it be another app? I ask because it is possible that Windows XP is defaulting to another program to try to open your file and can't so produces the error. If that's the case, reset Windows to open .ai files in Illustrator.
Hope that helps,
Michael
Michael,
Thanks for responding and I would have replied earlier but for some reason I couldn't see your response but now I do.
The error is definilty coming from Illustrator. The Illustrator window gets condensed to a small area in the upper right corner and then I get the error message there.
-Jane
From post 15 of this threaad:
http://forums.adobe.com/message/3899466#3899466
"I'll add an update to this problem using a Windows 7 Toshiba laptop running CS6 - I began to recieve the same message and Illustrator would resize itself to 1"h x 5"w box in the upper left of my screen. Illustrator itself would be hidden behind the error dialogue box.
This would happen when I'd select an Illustrator file in Windows Explorer. The first workaround was to maximize Illustrator and open the file through the Illustrator File>Open dialogue. This always worked.
The final fix was to manually resized illustrator to about 1/3 screen size and try to open the file again in Windows Explorer. Finally the files would open from Windows Explorer. Keep reading.
However, each time I opened a file Illustrator would do a little hula dance and resize a good bit smaller than what I'd manually set it to. It took about 4 resizes and 4 opening of files = each time resizing the illustrator window larger until it actually occupied the whole screen. It's working normally now."
Also, what happens if you open Illustrator and use File > Open?
--OB
Edit to add: There are other suggestions in that thread as well. Also several other threads dealing with the same subject if you search on the error message you are getting. <OB>
Thanks for responding OldBob1957. As I indicated in my original posting, I can open files using File>Open. It is inconvenient since I am used to do it the other way but where it is really a problem is that I can't edit an object from a pdf. When I select "Edit Object" from a pdf using Acrobat Pro it supposed tp open the (vector) object in Illustrator so I can edit it or check it out so File>Open doesn't help me there.
I had checked out that thread before and have tried the suggestions but nothing really worked. I am just concerned that everything was fine until a couple of weeks ago and now I am getting this issue.
This still sounds a bit like the windows directory that says what app opens which filetype is out of whack. To fix your Acrobat problem, you can tell acrobat to open object art in Illustrator via Acrobat's preferences.
here's a screen capture of Acrobat's preference indow:
Hope that helps a bit,
Michael
North America
Asia Pacific
