Just wondering if you know of any way of "resetting" the custom rotation
of an object such that InDesign considers it to be zero.
For example, let's say I draw a square. Then I rotate it 45 deg. so I've
got a kind of diamond shape. Now I want to pull the left and right
corners of the diamond -- but InDesign only lets me adjust the flat
sides of the diamond with the black arrow tool. (The white arrow tool
could be used to adjust each node individually, but that's a bit clumsy.)
Please let me know if what I'm asking isn't clear.
Ariel
Ah, that's quite clever! To amplify a little:
1. draw another object elsewhere on the page.
2. select both objects.
3. apply the the Add option from the pathfinder options.
4. draw a marquee round the object in (1) above with the white arrow
tool to select all the object's points.
5. press delete.
6. voila: the original object remains, with the rotation set to zero!
Good one, Jongware!
I wonder if it's scriptable? The two potential problems I envisage are
whether it's possible to apply pathfinder operations with scripting
(should be simple to find that one out; I expect it is possible), and if
it is possible, would it be possible to keep track of all the points on
the added object after applying the pathfinder operation, so that they
can be deleted afterwards?
Ariel
North America
Asia Pacific
