goffballz
Sharpen then render causing lines
Feb 12, 2013 6:40 AM
I'm having a problem when I sharpen a video, then render it, it causes some sort of weird interference; like blur and horizontal lines. It's only when it's rendered though. If I don't render, it doesn't cause the issue. Also, I can scroll through the sharpen percentage, and only the percentage I render at, will give the effect. Other percentages will not be affected.
Properties: 1920x1080 30fps progressive 30Mbps
I'm encoding to H.264 1920x1080 30fps progressive 30Mbps
The export shouldn't make a difference though, as I can see the interference in the sequence preview.
The sequence is made from the clip, if that helps to note.
Here take a look:
Rendered (sharpened at 10)
Not rendered (sharpened at 11):
Let me tell you, this is annoying.
  • joe bloe premiere
    Dec 6, 2009
    Feb 12, 2013 6:56 AM   in reply to goffballz
    Your 'lines' look like fields to me.
  • joe bloe premiere
    Dec 6, 2009
    Feb 12, 2013 7:12 AM   in reply to goffballz
    A sharpen effect would not interlace your footage.
  • joe bloe premiere
    Dec 6, 2009
    Feb 12, 2013 7:31 AM   in reply to goffballz
    I suspect that either your footage is interlaced to begin with,
    or you are introducing the fields in your export.
    Feb 12, 2013 7:38 AM   in reply to joe bloe premiere
    To actually get rid of the fields, you may want to send your footage into after effects. Then right click on the clip and go to interpret footage-main. There you should make sure in the fields and pulldown section that you have it set to probably upper field first for HD footage. If that doesn't work you could try lower field first. Then see if it removes those lines. You can still sharpen back in PP or do it in AE.
    Feb 12, 2013 7:42 AM   in reply to goffballz
    It very much looks like interlacing to me. Though without seeing your footage it would be hard to comment.
  • joe bloe premiere
    Dec 6, 2009
    Feb 12, 2013 7:49 AM   in reply to goffballz
    These screencaps would help:
    GSpot or MediaInfo for your source material.
    Your sequence settings.
    Your export settings.
    Sometimes it can be very hard to see interlacing. It may be more obvious
    when you are paused on certain frames, or may not be obvious at all.
    Regardless it very much looks like its there. Most US TV stations and
    TVs are working at 1920x1080 29.97i. Or interlaced. So I wouldn't be
    surprised if that was the frame rate most video game systems were
    playing back at as well.
    Again, not sure why you get the difference between two types of renders.
    When you say, when you "render it manually" vs just exporting, what do
    you mean?
    Feb 12, 2013 9:14 AM   in reply to goffballz
    Again, are you checking the box that says "Use Previews" when you export?
    If so, that is probably why.
    Premiere may have used a low-quality render codec like iframe mpeg as
    the default. So by using those previews you would be degrading your
    final image quality.
    Feb 12, 2013 11:56 AM   in reply to goffballz
    Using the "use previews" setting will use your in sequence renders for
    your export. So YES they are related. Check your sequence settings and
    see if they are i-frame mpeg or something like that for your renders.
    Chances are they are.
    Your best bet would be to create a new sequence manually. Proper frame
    rate and frame size, and for renders use something like custom-
    quicktime and choose an uncompressed or prores. If you are on a pc, then
    maybe use avi or whatever native hires settings you have. OR if you
    don't want to do this, don't "use previews" on export. It may still look
    wrong in your sequence due to your low quality render setting, BUT it
    should be right on export.
    you may want to watch these, whether you are coming from fcp or not
    there will be good advice.
    http://www.retooled.net/?p=116
    http://www.retooled.net/?p=123
