alexandre.imbert
name an png sequence
Feb 12, 2013 10:04 AM
hi evry one
i m exporting a png sequence from a "charcater" on  the scene which has many state. ("idle", "action","jump")
i'd like to name a png sequence and that it takse the name of either the label or the name of the graphic clip on the scene.
is it possible ?
    Feb 12, 2013 11:46 AM   in reply to alexandre.imbert
    Yes. The Following script will export a png sequence accroding to the framelabels you gave your animation.
    For example if you have frame 1 labeled as "idle" and in the same timeline frame 10 labeled as "action".
    It will output: idle_0.png; idle_1.png ...idle_9.png;action_10.png......
    Open your fla document with the animation in the timeline window.
    Cretae a new Jsfl file: File>New>FlashJavascriptFile
    insert this code in the jsfl file:
    var doc = fl.getDocumentDOM();
    var lyrs = doc.getTimeline().layers;
    var len = lyrs.length;
    var totalframes;
    var lyr;
    var i;
    var pngName;
    var saveName;
    var curLabel;
    var tl = doc.getTimeline();
    var saveDir = fl.browseForFolderURL("Choose a folder in which to save your exported PNGs:");
    if (saveDir) {
        for (i=0; i < len; i++) {
            lyr = lyrs[i];
            totalframes = lyrs[i].frameCount;
            for (j=0;j<totalframes;j++){
                if(lyr.frames[j].name !=""){
                   curLabel = lyr.frames[j].name;
                exportPng(j);
                //this advances the playhead
                tl.setSelectedFrames(j,j+1);
    function exportPng(j) {
        pngName = saveDir + "/" + curLabel + "_"+j+".png";
        doc.exportPNG(pngName, true, true);
        fl.trace("Exported: " + pngName);
    //code was inspired by this post
    Click on the RunScript icon (|>).
    Flash will ask you where to save your exported sequence.
    Choose a directory.
    Click OK.
    If Flash is ready you will find your files in the specified directory.
    Feb 13, 2013 1:06 AM   in reply to alexandre.imbert
    i'll hold you to that
