flash builder 4.7 air 3.6 new adt compiler
Feb 13, 2013 2:44 AM
Tags: #air #flash #export #builder #adl #adt #ipa #compile #3.6 #flash_buildler #air_3.6
Hi. Ive been having serious issues when i tried to "Export release build" using air 3.4 and/or air 3.5 on Flash builder 4.7. Goit a lot of nonsense java.lan.nullpinter exceptions and similar errrors.
When i tried to debug or run, even on device generating the ipa, everything ok. But when i tried to export the project, and it tried to re-compile it, always got absurd java errors.
Ive tried everything: downgrade the java virtual machine, reinstalling flash builder, air, even windows!!! Nothing worked. Even recovering previous stages of the project where I originally could export it (its even published on the appstore!). No use. The app that was working no problem, now when trying to export returns a lot of javanull pointers or similar crap.
BUT, when trying to generate the ipa through via command lines  on the ms dos console it works!! So... its obvious the problem was on the adl+java duo.
Thing is, I updated to the just released AIR 3.6 (not the beta, the release version). It uses .exes(on windows, which is the system im using)  instead of java, so it showed promise.
I overlayed the air version on the flash builder following this instructions:
http://forums.adobe.com/message/4797974
Well, not exaclty, because then flash builder throws a lot of errors and dosent show me the package explorer for instance.
I made a copy of the AIR folder, but not deleted the content, just copied the new air version files over and substitute the replicas, but kept the originals where no new file substituted them (dont know if im explaining it ok, sorry for my english).
It worked... except for the damn "Export release build" option. It keeps trying to debug it using java instead of using the new adt. And I cant find how to change that.
The adt on the other hand is being used ok, as i can check it when I try to run or debug the project targetting a device. Before I could check the command used and now Im not, so Im pretty sure its using the new .exe instead of the java version. But now I dont know how to generate the ipa targetting the app store, for instance via command line using the new adt nor can i do it exporting the project from the flash builder IDE.
SO...
is there anyone having similar problems?
How can I correctly overlay air 3.6 over Flash Builder 4.7 and force it to use the new air adt and adl?
Anyone tried?
Thanks in advance folks!!!
    Feb 13, 2013 9:04 AM   in reply to titozeio
    Feb 13, 2013 4:45 PM   in reply to titozeio
    When overlaying the AIR SDK on Flash Builder 4.7 - especially for mobile builds - I found that I had to overlay the AIR SDK on top of this directory as well:
    C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flash.compiler_4.7.0.349722\AIRSDK
    the version number might be different but look for something like that.
    Feb 13, 2013 5:17 PM   in reply to Nabren
    I'm getting 10 items in the Warnings when I overlay the AIR 3.6 SDK on Windows 7 with a new blank AIR desktop project.
    Description Resource Path Location Type
    Cannot resolve namespace qualified type 'List' in CSS selector 'List' SDKTest  line 9 Flex Problem
    Cannot resolve namespace qualified type 'Menu' in CSS selector 'Menu' SDKTest  line 4 Flex Problem
    Cannot resolve namespace qualified type 'Panel' in CSS selector 'Panel' SDKTest  line 4 Flex Problem
    Cannot resolve namespace qualified type 'TitleWindow' in CSS selector 'TitleWindow' SDKTest  line 4 Flex Problem
    Cannot resolve namespace qualified type 'VideoDisplay' in CSS selector 'VideoDisplay' SDKTest  line 14 Flex Problem
    Feb 14, 2013 8:04 AM   in reply to titozeio
    I'm having this same problem.
    I followed the instructions here:
    http://helpx.adobe.com/flash-builder/kb/overlay-air-sdk-flash-builder. html
    Unfortunately, the one thing I didn't do was backup the old sdk before doing this. D'oh!
    I've done AIR overlays with Flash Builder many times, but I followed the instructions exactly. When I came to this instruction, I deleted the contents of the AIRSDK folder:
    2. After taking a backup of the AIR SDK, delete all the contents inside the "AIRSDK" folder.
    In retrospect, I probably should have used the overlay method by running tar jxvf over the existing sdk. How can I now repair my installation?
    Here's a screenshot of my dilemma:
    http://interactivenyc.com/screenshots/Flash%20Builder%20AIR%20Error.png
    Feb 14, 2013 8:14 AM   in reply to speakaboo-steve
    By the way, I work on a small development team with 4 AS3 programmers. We're producing an app, and are getting ready to submit it to the store. We read the submission guidelines and discovered that we needed to ship certain assets inside the cacheDirectory folder rather than applicationStorageDirectory, and we saw that 3.6 had just been released out of beta.
    We use Flash CS6 to compile and Flash Builder for our code editing, like many other developers out there. This means that I had to download the AIR SDK twice, once for Flash and once for Flash Builder. Multiply this by four developers, and we downloaded the AIR SDK eight times yesterday. I'm the only one of us who has switched to FB7, and the steps to update AIR in FB7 are ridiculous.
    Here are two suggestions:
    1) Properly separate the Flex and AIR sdk's, and allow Flash and Flash Builder to point to the same files.
    2) Make it easy, like this:
    http://interactivenyc.com/screenshots/Flash%20Builder%20Update.png
    Feb 14, 2013 8:15 AM   in reply to titozeio
    Oh, hm... looks like I was going off an old page. It used to direct you to a different SDK folder. Try overlaying this folder with the new AIR SDK as well:
    C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\sdks\4.6.0
    Feb 14, 2013 8:25 AM   in reply to Nabren
    Thanks Nabren,
    I did that, but didn't get my code completion that way, and the Installed AIR SDK preferences still said I was using 3.4.
    -steve
    Feb 14, 2013 2:48 PM   in reply to speakaboo-steve
    Ya, the installed AIR SDK should update when you install the new AIR SDK to this folder: C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flash.compiler_4.7.0.349722\AIRSDK
    (Make sure you are doing this with Flash Builder closed)
    Also, make sure to delete everything under C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flash.compiler_4.7.0.349722\AIRSDK (but not the AIRSDK folder) before extracting the AIRSDK_Compiler.zip into that directory. Also make sure you downloaded the compiler version of the AIR SDK.
