Hi All,
I have a FM 10 book of nearly 200 pages and 7 chapters. It has a nice index (index of markers).
Today, I found out that the index is not getting updated when I am updating the book. The new entries are not coming.
The option "Generate Table of contents, Lists and Indexes" is selected while updating. And it was working fine previously, this problem much came in recently. I noticed it today.
When I try to generate a new index, the generated file comes blank. Though the index entries in the book are all right, FM is not detecting them.
I will very much appreciate some quick help in this matter.
Regards,
Com
> ... steps to re-recognize the file in FM?
Assuming your book is MyTome.book and the IX file is MyTomeIX.fm
This works on alternate Wednesdays and in FM releases that are prime numbers.
I do not have 2 IOMs defined in the Reference page.
After some R&D, I am being able to add a new index in the following way:
1. Click/Select the book file.
2. Click Add > Standard index.
But the new index file do not seem to use our master page. But I imported these (all formats including masterpages and ref pages) from the old index file and now it is looking all the same.
My question is: This will be pretty much identical to the old index, right? I just want to make sure I am not spoiling up. Everything looks the same though. Do I need to change a few settings somewhere?
Error, I am not being able to ressuract the old index as you stated, need to go with the new one.
Perhaps I misunderstood your initial post...
If you are creating a standard index (with a suffix of IX), you likely have 2 IX definitions in your reference pages. When you import the ref pages back into your new doc, you reintroduce the problem.
Either reformat your new index, or avoid importing your reference pages from the bad IX into the new and you should be fine.
That's Plan B, and is a more reliable route, but is more work than Plan A.
> ... I am not being able to ressuract the old index as you stated ...
What happened?
North America
Asia Pacific
