xxMTown
can't see color correction until render
Feb 13, 2013 11:38 AM
Tags: #help #cs6 #color_correction #adobe_premier_pro
whenever i add like "fast color corrector" or "three way color corrector" the entire video goes black. i have to render each and everytime i make changes to view what i actually did. is there anyway to fix this?
    Feb 13, 2013 11:49 AM   in reply to xxMTown
    Reread the questions more carefully.
    Feb 13, 2013 11:58 AM   in reply to xxMTown
    Wild guess: Change .mov to .mpg before importing and try again adding FX effects.
    See if that will help not getting black monitor.
    Feb 13, 2013 12:28 PM   in reply to xxMTown
    I mean change the extention.
    Or do wmv or mpg files give you the same black screen?
    Feb 13, 2013 12:41 PM   in reply to xxMTown
    OK. Try this.
    Start Premiere with holding shift+alt down until welcome screen.
    Feb 13, 2013 12:47 PM   in reply to Ann Bens
    Make sure the 6.0.3 update is applied to Premiere. Update display card driver. Change Display Resolution (bottom right of window) to half or full.
    What are your PC hardware specs? Display card?
    Jeff Pulera
    Safe Harbor Computers
    Feb 13, 2013 1:53 PM   in reply to xxMTown
    So what Processor do you have? Memory, graphics? Perhaps the laptop is inadequate for the task?
    Jeff
    Feb 13, 2013 8:39 PM   in reply to xxMTown
    Here are the tech specs for Premiere Pro CS6: http://www.adobe.com/products/premiere/tech-specs.html
    See if your machine meets the requirements.
    I have a feeling your "Mobile Intel(R) series express chipset family," (which is actually a GPU that is integrated with the main system board) might mean an underpowered computer. This integrated GPU might not meet the minimum tech specs, and it's not replaceable because of its integration with the system board.
