attm&pmanger
Index.htm file
Feb 13, 2013 1:45 PM
RoboHelp 8 > WebHelp
I'm having difficulities viewing my project in a Web browser (IE 8) because it is missing the index.htm file.  How do I add this file to my project so that it appears in the SSL! folder?
    Feb 13, 2013 1:48 PM   in reply to attm&pmanger
    Are you talking about the actual index or the start page for the generated help? If it's the latter, then you specify that in your SSL recipe.
    Feb 13, 2013 1:58 PM   in reply to attm&pmanger
    just right click on the SSL layout you use and check the properties; it's one of the first questions you get in the WebHelp (not WebHelp Pro) layout
    Feb 13, 2013 9:41 PM   in reply to attm&pmanger
    Hi attm&pmanger,
    In RH8 the start page of output was by-default having the name of project. Did you change the start page name to index.htm?
    In order to confirm this please open the SSL properties in RH8. There will be a text field named "Select output folder and Start page". PLease observe this field, this path shows the name and location of start page. You can copy the name of file displayed in this field to your production server location. Now access the help from production server using this file name.
  • RoboColum(n)
    Oct 8, 2004
    Feb 14, 2013 1:02 AM   in reply to moszapy1
    Just so it is clear the default with any new project is to make the file name used to launch the help the same as the project name. For example if you project is called project the file is project.htm. However in web circles it is common - indeed good practice - to make the start page index.htm. This could be what your web admin peeps are looking for. So if you haven't specified this in the SSL the actual start file will be <projectname>.htm.
    Feb 14, 2013 3:00 AM   in reply to RoboColum(n)
    @RoboColum(n) The poster is using Rh8 so what you say is correct. However, to avoid anyone reading your reply out of context, that changed in Rh9 and new projects are assigned the default of index.htm.
    @petergrainge
    Feb 14, 2013 8:17 AM   in reply to attm&pmanger
    in the SSL pod you should see the list of various help outputs - find the one that you use (it's probably marked as the default or primary layout), right-click on it and check the Properties
    Feb 15, 2013 9:37 AM   in reply to attm&pmanger
    How is the help getting from your !SSL! folder to the server?
    Key point is you are creating a start page Conversion-Worklists.htm and the developer is calling index.htm. I rather puzzled as to how you are getting anything.
    @petergrainge
