There are a couple of irregularities in the markup
1. Line 12 a stray <br />. This irritates IE
2. Line 85 the red highlighted quotes are missing
codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#ve rsion=6,0,29,0"
3. Line 91 a stray </embed>
Looking at the raw XML file, there are some irregularities such as extra blank lines (e.g. line 412). I don't think these matter, but it is worthwhile keeping in mind.
On my test server, I added another 150 odd lines to the XML and noticed no problem.
I did, what I usually do, place ALL scripts and links to scripts at the bottom of my document. Don't know if this makes a difference, but again it worked for me.
Thank you very much for your advice.
I tried everything but it makes no difference.
Only some scripts aren't properly compiled when I place them outside the <head>, so I put them back.
The <embed> is necessary to display the .swf.
You were right it's an IE problem - Chrome and Firefox display ok.
I've left it live, so you can see the problem.
Sorry for the delay, I have spent some time trying to find the culprit. Finally I decided to start afresh with the following markup, which works quite well in all browsers.
<!doctype html>
<htm>
<head>
<meta charset="utf-8">
<title>Untitled Document</title>
<link href="SpryAssets/SpryAccordion.css" rel="stylesheet" type="text/css">
</head>
<body>
<div id="Accordion1" class="Accordion" tabindex="0">
<div class="AccordionPanel">
<div class="AccordionPanelTab">Label 1</div>
<div class="AccordionPanelContent">
<div id="div1">
<table align="top" cellpadding="5">
<tr id="tr1">
<td valign="top">{datum}</td>
<td valign="top"><a href="{link}">{inhoud}</a></td>
</tr>
</table>
</div>
</div>
</div>
<div class="AccordionPanelTab">Label 2</div>
<div class="AccordionPanelContent">Content 2</div>
</div>
</div>
<script src="SpryAssets/SpryAccordion.js"></script>
<script src="SpryAssets/SpryData.js"></script>
<script src="SpryAssets/SpryDOMUtils.js"></script>
<script src="SpryAssets/SpryTooltip.js"></script>
<script src="design_template_info12.js"></script>
var Accordion1 = new Spry.Widget.Accordion("Accordion1");
</script>
</body>
</html>
May I suggest that you copy and paste the markup into a new document to then start adding your own stuff, making sure that you test in IE7 or IE8 at each step.
Note that I have left xpath.js out of the markup. I think it will work either way. Just keep an eye on it.
PS
I did reformat the XML to delete all of the empty lines. Not sure if this helped or not. You can do this within DW as follows
Message was edited by: Altruistic Gramps
I can't get it working when arranged like this. Basicaly, when i only want to display the xml data it won't work. In <HTML xmlns:spry="http://ns.adobe.com/spry"> seems necessary - although an error message when validating.
played with div tags but that didn't work. the only thing that fixes this poblem is removing
| <div style="clear:both;" ></div> |
but when i do this the div blocks are completelely misplaced in the display. Quite strange that this solves the XML problem.
Maybe i"ve messed up something in the code, but i really have no idea.
I'll take a closer look at the <div> nesting, maybe that's an issue.
North America
Asia Pacific
