Title Tool - text rendring too soft/blury
Feb 14, 2013 4:44 AM
Tags: #title_tool #soft_text
used the Premiere Title Tool occasionally and always got to soft/blury text rendering - it seems optimal for old CRT tubes and interlaced video but looks bad on a 1080p 4:4:4 timeline
If for example I want to add some Text to a imported Photoshop PSD title it doesn't match - because the Premiere Title Tool added text looks soo blurry and washed out compared to the text from the PSD title...
hmm - don't found any setup properties to turn off blurring or something like that...
    Feb 14, 2013 7:59 AM   in reply to nw42
    PP does anti-aliasing better than AE or PS.  Hence the apparent 'softness'.  You may have to add the additional title in PS, next to the first one.
    Feb 14, 2013 9:42 AM   in reply to Jim Simon
    When you say it is "rendering" too soft, do you mean when you render your timeline? If so, what is your preview format set to? If it is something like i-frame mpeg, it may very well make it blurry. Is it blurry on export (without the setting use previews checked)?
    Feb 14, 2013 12:02 PM   in reply to reToolednet
    What he's seeing is the result of PP's stronger antialiasing.  If you create the same text in PS, PP and AE, then get a PNG of all three and compare, you will see the difference.
    Feb 14, 2013 12:08 PM   in reply to Jim Simon
    yeah, premiere's titler defintely is aliasing more than the others. not
    a fan.
    Feb 14, 2013 12:15 PM   in reply to reToolednet
    I like it.  I find the text 'smoother' looking.  And if you want it 'sharper' (read: more jagged), you can always use PS or AE.
    Feb 15, 2013 9:33 AM   in reply to nw42
    Nope.  You'll have to use PS or AE to create your titles.
