.MTS files no sound
Feb 14, 2013 11:03 AM
We use Premiere Pro to edit .MTS files.  We have constantly experienced problems with Premiere Pro not importing sound.  Usually, updating everything (not just Premiere Pro) will solve this.  We currently have one machine were nothing is working, and right this second, we are deleting Premiere Pro to reinstall and try it again.
  This nonsense of constantly battling to get Premiere Pro to import sound has been going on for months.  Why is this such a horrible ongoing battle?  Is there something we can do?
    Feb 14, 2013 12:43 PM   in reply to minnow68a
    Moved from the Creative Cloud to the Premiere Pro forum. They will be able to help you here.
    Feb 14, 2013 3:08 PM   in reply to minnow68a
    The two most common causes of a loss of Audio in MTS files is that the Conforming process was not allowed to complete - can result in no Audio, or truncated Audio, and not Copying the full folder structure (not just the media files), from the memory card.
    If you have insured that Conforming HAS completed 100%, and have Copied the full folder structure, then something else is amiss.
    Feb 15, 2013 2:53 PM   in reply to minnow68a
    For those two causes, it is not the program, that is faulting, but either a poor workflow, or impatience, that is the cause. If the cause is incomplete Conforming, then I would Delete the Assets, clean the Media Cache, and Reimport those Assets, allowing the Conforming to complete. If the cause is a lack of the full folder structure, then I would Copy that full folder structure to the HDD, from the card, Delete the Assets, clean the Media Cache and Reimport again.
    Now, if neither of those suggestions fix things, perhaps the cause is something else, and could well be either program-specific, or Asset-specific.
    The Uninstall/run the CS Cleaner several times, rebooting between each run/Reinstall is sort of a "last resort," though has been known to fix some issues.
    Feb 15, 2013 5:33 PM   in reply to minnow68a
    The question of "how long should we wait," is shown by a progress bar, during the Conforming stage of the Import operation. When it disappears, then Conforming should be complete. This article goes into more detail: http://forums.adobe.com/message/4330843#4330843
    As far as the workflow, exactly how are you handling the folders and files from your card? Are you Copying over the entire folder structure, or just the media files, themselves? Please give us the full details of how you are transfering the files from the card(s), to your HDD, as that will likely tell part of the story.
    Feb 16, 2013 12:06 PM   in reply to Bill Hunt
    Bill,
    I had a similar problem yesterday where I imported about 30 short to longish clips (3 minutes to 30 minutes) and some of them had no audio.  I wasn't in a rush so I deleted all the clips from the project and re-imported them.  When I did this the conforming bar **never** started.  I thought it might be because the project "remembered" them somehow so I started a brand new project and imported the clips.  Still no audio in some of them and I'm positive all the clips actually have audio
    I am *religious* about copying the entire folder structure (I drive my co-workers nuts about it) and I usually just import clips through Media Browser and walk away for awhile so the conform bar will finish.  What is particularly odd is that most of my work is long-format (1 hour+) and I never have this problem with long spanned clips.  I have had it a couple of times before and always with short clips.  It's never all the clips.  Just a random couple here and there.  Any ideas?
    Camera is a Canon Vixia H300
    Feb 17, 2013 3:39 PM   in reply to minnow68a
    media browser only sees about half the files that are actually there!
    That's normal.  Often a clip will take up multiple files, due to the FAT32 limitations on the SD cards.  Media Browser shows you the first file from that group, but does properly bring in all the video.
    So if a clip takes up file 05, 06 and 07, MB will only show you 05, then go on to 08.  That's because files 06 and 07 are actually part of clip 05.  So MB brings in all three as a single clip.
    May 4, 2013 11:56 PM   in reply to minnow68a
    ok why has no one mention VLC media player???????   I converted my MTS files using this and it worked!    Dont worry about re installing and all the other garbage coz I have tried it all.  Use VLC and all good
    May 5, 2013 12:08 AM   in reply to Lisa01707
    Its a media player or a  converter ? How did you converted the files ? I am having the same problem ...
    Yf somebody here please take a look at this > http://forums.adobe.com/message/5291123#5291123
