Donald Mazer
Using Photoshop cs6 with Pre elements11
Feb 14, 2013 2:29 PM
Is there a quick way to switch back and forth between Pre 11 and PS cs6?
Don
    Feb 14, 2013 2:34 PM   in reply to Donald Mazer
    There is not, as the two programs have no real connection, as one would have with other programs in the CS 6 suite, such as PrPro, After Effects or Encore, and will also lack the links that allow direct connections between PrE 11 & PSE 11.
    They are viewed as totally stand-alone programs.
    Feb 14, 2013 2:58 PM   in reply to Donald Mazer
    If you are on Windows, you press ALT + Tab key to switch applications
    Feb 15, 2013 6:15 AM   in reply to Donald Mazer
    Don
    Yes, if you have psd on the timeline or in the Project Assets window rightclick on the psd and Edit Origial. Even the layers are preserved in PS.
    As for jpeg etc. they need to be set (opened with) Photoshop before importing.
    When adjusting them in PS they need to be flattend before saving.
    Feb 15, 2013 8:04 AM   in reply to Ann Bens
    Ann,
    Great call. I had not thought of Edit Original, as I am so used to just working between PrPro and Photoshop, it never occurred to me. Thank you for that tip.
    As you point out, the file type associations will need to point to PS CS 6, but that is easily done.
    Greatly appreciated, and you got me "thinking outside the box!"
    Feb 15, 2013 10:35 AM   in reply to Bill Hunt
    Premiere has a extra feature called edit in Photoshop but its exactly the same as Edit Original.
    You might want to install E11 and try things out.
    Don: if you have Audition you can use that for audio files.
    Feb 15, 2013 10:35 AM   in reply to Ann Bens
    With the CS suites, I use "Edit in Adobe Photoshop" for that operation, but you are correct, "Edit Original" works the same way - I just did not think about it, until you mentioned it.
