Clone Stamp and some other tools not working correctly
Feb 15, 2013 2:49 PM
I have some problems with th CLONE STAMP TOOL at the right hand.
Sometimes it works and sometimes it doesnt.
I do the correct thing: I press ALT-button, the click.
Can anybody help me?
I have also noticed that this also is a problem when I use the BURN and DODGE tool.
Message title was edited by: Brett N
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 3:33 AM   in reply to LeneMarie123
    Try selecting the tool and do a re-set.
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 3:40 AM   in reply to LeneMarie123
    Select clone tool
    Click top left (small triangle for dropdown menu)
    Choose reset tool
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 3:52 AM   in reply to LeneMarie123
    No need to install again.
    You may need to rebuild the editor preferences to resolve any conflicts. To begin, close Elements.
    Hold down the Ctrl+Shift+Alt keys and simultaneously click on the Edit button on the welcome screen. Release the three keys and look behind the welcome screen by closing it. Or hold down the keys whilst clicking on the desktop icon for the Editor or PhotoshopElementsEditor.exe in the Programs folder. Keep holding down all three keys for a few seconds; then release. You should get the settings option.
    You should see a pop up box with the words: Delete Adobe Photoshop Elements Settings File?
    Click on Yes
    Then wait whilst Elements rebuilds the preferences.
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 3:59 AM   in reply to LeneMarie123
    It's OK to do it - nothing will get destroyed.
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 4:33 AM   in reply to LeneMarie123
    Are you using a laptop or notebook?
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 4:53 AM   in reply to LeneMarie123
    Are you using the clone stamp or the pattern stamp?
    Press the S key, then again to tab between the two choices.
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 4:58 AM   in reply to LeneMarie123
    You press alt and click to sample. Then move your mouse and paint over the area you want to cover up with the sample. Is that what you are doing?
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 5:06 AM   in reply to LeneMarie123
    Did you re-set the prefs using Ctlt+Alt+Shift?
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 5:11 AM   in reply to LeneMarie123
    How do you normally launch the Editor?
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 5:18 AM   in reply to LeneMarie123
    How do you open or start the Editor?
  • 99jon
    Jan 6, 2010
    Feb 15, 2013 5:39 AM   in reply to LeneMarie123
    Keep all three keys pressed together for a few seconds then release.
    Click yes to delete settings.
    Feb 15, 2013 9:11 AM   in reply to LeneMarie123
    The other clone stamp you are seeing soundls like you have some of the overlay options turned on. If this bothers you, click the overlapping gray rectangles at the right end of the options bar and turn off everything there;
