Joachim Smith
Can't get Image Matte Key to work in PP CS6 Mac
Feb 15, 2013 5:49 AM
Tags: #key #composite #matte
After tearing my hair and muttering adult phrases for a couple of hours while following the below instructions from the PP CS6 pdf manual, I still can't get anything but a black screen when trying to apply the Image Matte Key to a simple set-up. The project is in HD 1080p50 format and the basic editing has been largely problem free.
  1. Add the clip (used as a background) to a video track in a Timeline panel.
  2. Add the clip you want to superimpose to any track higher than the track containing the background clip. This is the clip revealed by the track matte.
    Be sure the superimposed clip overlaps the background clip in a Timeline panel.
  3. In the Effects panel, click the triangle to expand the Video Effects bin and then click the triangle to expand the Keying bin.
  4. Drag the Image Matte Key to the superimposed clip in a Timeline panel.
  5. In a Timeline panel, select the superimposed clip.
  6. In the Effect Controls panel, click the triangle to expand the Image Matte Key settings.
  7. Click the Setup button , browse to the image being used as the matte, and then click Open to select the image.
  8. (Optional) If you’re animating the Image Matte Key over time, make sure that the current-time indicator is in the position you want. Click the Toggle Animation icons for the settings you adjust.
  9. Click the Composite Using menu and choose one of the following:
    Matte Alpha Composites the clips using the alpha channel values of the image matte you selected in step 7.
    Matte Luma Composites the clips using the luminance values of the image matte you selected in step 7.
What I do is:
• I have a clip on Video 1. I want to use a hand painted luma matte made in PS CS6 for changing levels ('exposure') in an irregular area of the clip.
• So,  I duplicate the clip on Video 2 and add an 'RGB Curves' fx for the level adjustment.
• Then, I add the Image Matte Key to the Video 2 clip and set up the Photoshop b/w image (RGB 8 bit, 1920x1080) from my external eSATA disk containing the Project and media (step 7 above).
• I select 'Matte Luma' (step 9) – and expect the relevant part (painted white on the matte .psd pic) of the duplicated, level adjusted clip to be superimposed on the Video 1 clip.
• But I only get BLACK!
I tried using Track Matte Key, with the matte pic on Video 3 – no problem, worked just as expected.
So, what's the voodoo with Image Matte Key?
Kind regards,
Joachim
    Feb 15, 2013 7:51 AM   in reply to Joachim Smith
    I just tried your set up and I get no black screen.
    Restart Premiere and try again.
    Feb 15, 2013 8:14 AM   in reply to Joachim Smith
    Sorry. Me too.
    I created a black and white matte in Photoshop, put the same clip on one and two. Adjusted the colors of thr video on track two using the RGB Curves, added the image matte key, told it to use the PSD I created, set it to use Luma, and it worked exactly as expected.
    So, perhaps you need to provide more information about the image you used and the video itself?
    Feb 15, 2013 9:10 AM   in reply to Steven L. Gotz
    A screen-cap of the Timeline with the Clips and Track Matte would probably be useful too, so that others can see exactly how you have things laid out.
    Feb 16, 2013 7:52 AM   in reply to Joachim Smith
    Joachim,
    Glad that you got it sorted out in your Project.
    I have not encountered an issue with Saved versions of my PS Track Mattes (or altered versions), but also do not recall having to make any changes after the creation - so maybe just never experienced what you saw?
    About half the time, I create my Track Mattes with Titler, and the other half, they are created in PS, and just Imported. To date, they have worked, as expected for me.
    Good luck, and thanks for sharing the cause, plus the good news that you got things working correctly.
