chrisdq82
How to get 2 program monitors?
Feb 15, 2013 2:10 PM
Tags: #premiere_pro #cs6 #waveforms #program_monitor #scopes #reference_monitor
So i'm using the reference monitor to check exposure and color and what not, but the reference monitor doesn't show a live feed during playback. It will only show me my reference information when i pause playback in the Premiere Pro sequence. Using CS6 by the way.
So i learned that my scopes can also be displayed in the program monitor, but then i can't see my footage.
is there no way to playback my footage AND see live waveforms and scopes? this is really getting frustrating to me. Or a way to get 2 program monitors so i can set one to all scopes and the other to composite video?
thanks in advance!
chris
    Feb 15, 2013 3:13 PM   in reply to chrisdq82
    Nope.  Please yell at Adobe for this.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Feb 15, 2013 4:11 PM   in reply to chrisdq82
    The current simplest solution is to use multiple monitors. I'll post a picture tomorrow to show you what I mean, but in darkness the flash corrupts the picture too much.
    Feb 15, 2013 8:35 PM   in reply to chrisdq82
    Open a Reference Monitor and  set it to display  whatever scopes you  need.
    You will then have the Program Monitor displaying  your Sequence ( timeline) and your Referene Monitor displaying scopes of your choice.
    Harm M. was talking about  taking a photo of his set up just so you know
    Feb 15, 2013 11:20 PM   in reply to chrisdq82
    OK, I think I can take a picture of this and get away with it - without a flash. (I had to back way up because I had a 45mm Prime on the camera and I was too lazy to put the 14-140 lens on in order to stand closer.)
    I believe what Harm was going to show you is the left hand monitor. If you have two monitors, go into the Edit / Preferences / Playback settings and check the box next to your second (or third) monitor.
    Here is a photograph of my screens. Not perfect, but not terrible. I think it will get the point across. I obviously can't post a full size image since it would not fit on most people's monitors. If you are using your Program monitor to look at scopes, then play the video on a different monitor. No, it is not the Program Monitor. It is better. Of course, yours might be on the right and not the left, but that is merely an individual preference.
    Oh, and just in case you were wondering, I chose a frame to display that was way out of whack for white levels on purpose. I thought it would add more flavor.
    Feb 16, 2013 2:06 AM   in reply to Steven L. Gotz
    It is a repeating message after Steven's post, but this is what I wanted to show:
    This allows for source monitor, program monitor with all scopes showing and a full display of the program monitor and the scopes are updated all the time when playing the timeline.
    Feb 16, 2013 4:16 AM   in reply to Harm Millaard
    Having the scope on one monitor and the timeline on another is not very convenient.
    I like to see them side by side on one monitor.
    Feb 16, 2013 4:28 AM   in reply to Ann Bens
    100% scale external video monitor should be mandatory - but even if you have - scopes doesn't work flawless...
    If you use the MPE GPU Mode and adjust colors or move video layers around they don't update in realtime on the external monitor... so you can't check color changes in realtime on the scopes :-(
    also the scopes performance is going down if GPU effects are activated...
    So the scopes need some work to perform as expected - also a histogramm is missing...
    (external solutions like an BMD Ultrascope are expensive and complicated to install if you don't use SDI wiring - so it would be the better route to install another GPU to get some shader performance free for the scopes instead of setting up another PC...)
    Feb 16, 2013 6:46 AM   in reply to Ann Bens
    What is stopping you from this configuration?
    Feb 16, 2013 7:25 AM   in reply to Harm Millaard
    Hi Harm,
    "What is stopping you from this configuration?"
    --> I use Premiere with MPE GPU and external monitor connected via Display Port
    1. If I set the programm monitor to scopes I don't see color corrector adjustments in realtime at the external monitor.
       (I see realtime scopes at the program monitor but the external monitor isn't updated since I stop dragging a slider - so I don't see the color change until mouse release...)
    2. same thing if I transform a video layer - if for example I move a video layer I don't see the movement on the external screen until mouse release - so you don't can move it interactively to a new pos. (on the proram monitor set to scopes everything is updated in realtime)
    3. Premiere scopes are running smoothly as long as no effects are applied to the sequence - so I have to decide between realtime scopes versus realtime GPU effects on the other side (with GPU effects the scope refresh becomes very slowly)
    as long as I don't saturate CPU or GPU shaders to much I don't see why the scopes are slowing down... (I suspect they are implemented in a way that doesn't run smootly along with te GPU effects)
    Feb 16, 2013 7:53 AM   in reply to nw42
    Oh well, then I suppose you need to add your name to the list.
    I have never used a workflow that required realtime scopes during color correction, so it isn't an issue for me. But perhaps adding your name to a list with Ann's name on it could be the final push needed to get Adobe's attention.
    Feb 16, 2013 8:28 AM   in reply to chrisdq82
    Hi chrisdq82,
    Yes - you set the program monitor to scopes and connect an second external fullscreen video monitor...
    when you press play - you will get "realtime scopes" in the program monitor and fullscreen playback at the external monitor as you wanted...
    Feb 16, 2013 8:35 AM   in reply to chrisdq82
    Please read post #7. If that doesn't help, I will put together a tutorial.
    Feb 16, 2013 8:38 AM   in reply to chrisdq82
    as Steven already wrote above:
    He also had a screenshot in his post...
    Feb 18, 2013 5:55 PM   in reply to chrisdq82
    Persistance? When you want something bad enough, you keep after it.
    Glad to hear it worked out for you.
