2 columns dropdown
Feb 15, 2013 4:04 PM
I would like to have a dropdown box 2 columns like employeeNO and EmployeeName.
It think that I only can have one column from my recordset.
I tried to add a new column from my recordset, but I am unable to add extra field.
I would like to know does DreamWeave allow me to do this or I am not on the right track.
Your help and information is great appreciated,
regards,
Iccsi,
    Feb 16, 2013 6:01 AM   in reply to iccsi
    After having created the dropdown list using DW, you will see somthing like
    <select name="mySelect">
      <?php
    do {
      <option value="<?php echo $row_rsEmployees['UserID']?>"><?php echo $row_rsEmployees['UserID']?></option>
      <?php
    } while ($row_rsEmployees = mysql_fetch_assoc($rsEmployees));
      $rows = mysql_num_rows($rsEmployees);
      if($rows > 0) {
          mysql_data_seek($rsEmployees, 0);
          $row_rsEmployees = mysql_fetch_assoc($rsEmployees);
    </select>
    Open the bindings window select and drag the field name to the option
    to finish up with something like
      <?php
    do {
      <option value="<?php echo $row_rsEmployees['UserID']?>"><?php echo $row_rsEmployees['UserID']?> - <?php echo $row_rsEmployees['UserFirstName']; ?> <?php echo $row_rsEmployees['UserLastName']; ?></option>
      <?php
      if($rows > 0) {
    </select>
    I know that you are using CF and the above example uses PHP, but the principle remains the same.
    Feb 16, 2013 6:43 AM   in reply to iccsi
    From memory, more than 10 years ago, I think it is <cfoutput>#messgae#</cfoutput>
    Feb 16, 2013 7:06 AM   in reply to iccsi
    That is correct, you should have
    <cfoutput query="Recordset1">
          <option value="#Recordset1.EmpID#">#Recordset1.EmpID# - #Recordset1.FirstName#</option>
    </cfoutput>
