I'm using Data Merge to place a single image on each page. I have the frame centered on the page and its reference point set to the center. I have the Data Merge options set to "Fit frame to content", but when I run the merge all the images align to the top left corner of the frame. The frame expands or contracts as directed, but I would like for it to expand from the center. What am I failing to do?
are you setting the reference point in the right place? You need to do this in the Frame Fitting Options.
hope that helps,
Michael Riordan
Adobe Certified Instructor
Digital DesignLab
http://www.learnadobesoftware.com
Sent from my iPad
I feel the OP's frustration.
Normally to center an item within a data merge, the controls for that are within the content placement options in the data merge flyout - it's the center in frame checkbox:
However as the OP has realised, it doesn't work for "fit frame to images" - instead the frame fitting options take the measurement from the top left. There is a workaround:
Voila! it should work.
Yes, the same thing can be achieved by drawing a frame larger than the largest image that is part of the merge, and then from the content placement options, choosing "preserve frame and image sizes" and having the center in frame checkbox turned on... the advantage with the method above is that the image has its frame around it to the right size that will scale when the image does... the "preserve frame and image size" won't allow this.
If I'm not explaining myself properly, go to https://dl.dropbox.com/u/55743036/2013-02-17%20centering%20dm%20pics.z ip and download the files to see what I mean. Missing links may appear... simply substitute them with the intended data merge.
Colly
Peter, I thought that might be the case, so I did everything from scratch on a page. No luck there.
Colly, thank you very much. I ran a test with your files and, sure enough, Bam!, right in the center.
Tomorrow I will configure with my files and report back.
Again, thanks!
Edit: I tried to recreate the page by your instructions, but images still imported to the upper left corner.
The second method mentioned worked fine and my images require no scaling. However, I just used the file you provided.
Thanks for the help! I'm quite grateful.
North America
Asia Pacific
