I am on OS X 7.5. I have reloaded InDesign6 several times. After about a day of use, it no longer recognizes some plugin's. Every time I open it, more are added to the list.
Can anyone help?
The Application Managre keeps going bad too where I have to reinstall that.
I do not have 5 installed I did a cleaning with Adobe's software.
Sorry, did you run the Creative Suite Cleaner Tool?
That is intended to be used after you have uninstalled a product, if and only if the uninstallation does not succeed. If you've run the cleaner tool, then you need to re-run the installer software and reinstall the program.
Is that what you did?
Or have I misunderstood?
John may be back later, but I think he's getting buried in snow at the moment.
Those errors are, to say the least, unuusual, particularly if they only pop up after you've used the program successfully. This leads me to think there's probably an external cause, perhaps some other program or utility that you are running that is conflicting with ID.
Well, there is snow, but I can't rightly claim it as my excuse.
JGP, this is not a normal problem. I have to suspect something's quite wrong with your system.
Have you confirmed that the plugins it complains about are actually present in your Applications/Adobe InDesign CS6 folder? Do you have teenage gremlins messing around with your computer?
I don't think the crash report tells us a whole lot, but if random pieces of InDesign are disappearing out from under it, it's no surprise that it crashes. Peter asked a bunch of questions in post #8, it would help to see their answers.
What else correlated with your one day of use? It's not normal for this sort of thing to happen, so I would look at external causes. Did it coincide with a reboot or somesuch? Did you restart the app? Did you do so at times prior to the one day mark?
I don't have any explanatino for you. It really sounds like someone is going and deleting parts of the application from your hard drive, and of course you can't be doing that deliberately. Maybe its a virus.
I gave up on Carbonite for Mac a couple of years ago. After almost two years of installing "this should fix it" updates, it didn't. Each tech-support contact found more and more that Mac system processes were updating some local files so they never were marked "backed up," which hung Carbonite, even after the troublesome files were removed from the backup list. IOW, I never got even one full backup in two years!. Also, at that time, anyway, the revert-to-earlier-file-version feature wasn't enabled for Mac, only for Windows.
So, try deactivating Carbonite.
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
So John, you think carbonite might be the issue?
To answer the earlier Questions:
No one eles uses this system. So a person is not doing it.
How would I go about finding out if there is a virus and how to cure that?
I have another ID on this already but they share the software and the same thing occurs.
The system does not fully start up with the shift key being held. I waited 10-15 minutes and it seemed stuck. I just had it looked at by a MAC stor and they found nothing wrong with the harddrive, but reloaded OS X on it.
Err, get some virus software and run it? This is not necessarily a trivial task. It's a continuous war between the virus creators and the virus eradicators.
Well, this seems a problem, in two ways.
If you reinstall the OS after having installed Adobe products, you should expect you'll have to uninstall and reinstall the Adobe software.
And of course, if its taking 15 minutes to boot, then something is clearly wrong. You could perhaps hold down Cmd-V while booting for more information.
I have no personal experience with it. But it's one of the few nonstandard things about your system, so sure, it could be.
Sorry to not be more helpful.
So this is still a problem. It lasted three days and then the Links plugin quit working. I reinstalled InDesign and it worked a day and a half. The Links plugin again is not working. I tried to replace it with one from my laptop and that does not work either. It will not start up again. This is looking like I have to uninstall and reinstal every coupld days which takes a few hours for the download.
Any other ideas?
This nightmare doesn't want to end. I ran nothing but InDesign, Entourage and Microsoft Word, Safari, Illustrator and Photoshop this weekend and InDesign wil not even open tonight. Niether will Adobe Application Manager which has also been a problem in this mess. Any issues out there with that? I keep reloading that too.
North America
Asia Pacific
