5deMayo
Can't Place Captivate 6 swf or html5 File into Muse v3.2.
Feb 16, 2013 3:34 PM
Tags: #swf #captivate #muse #html5 #error_encountered_during_import
Muse v3.2 won't place my Captivate 6 swf or html5 files. "Error encountered during import" error 0. Has anyone else solved this or a similar problem? What can I do? Suggestions welcome.
    Feb 17, 2013 12:09 AM   in reply to 5deMayo
    You should be able to add Captivate 6 SWF file through Object -> Insert HTML option and using the below code. Replace the highlighted part with your file name and edit height and width as required. You would also need to upload captivate6_file.swf manually through FTP.
    <object width="800" height="600"
    classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
    codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab# version=8,0,0,0">
    <param name="SRC" value="captivate6_file.swf">
    <embed src="captivate6_file.swf" width="800" height="600"></embed>
    </object>
    Vinayak
    Feb 19, 2013 8:54 PM   in reply to 5deMayo
    Hey Mark, you do not have to place the .SWF in your Muse project. Instead you need to manually upload the Captivate file to your server via any FTP client like Filezilla at the desired location and update the path in the code above referencing the file. I was able to reproduce the error message during my tests with a Captivate .SWF however this method worked!
    Vinayak
    Feb 19, 2013 11:11 PM   in reply to 5deMayo
    Just a note, you can also use the File -> Add Files for Upload option (instead of going the manual FTP way) and select your captivate6_file.swf for it to upload when you publish the site. The file would be uploaded to the /assets/ folder, so you might want to update the code to reference this file. Following this approach would allow you to preview the SWF playing in Muse's Preview mode as well.
    So in order to test this out, simply add the below code to a page through Object -> Insert HTML and add your .SWF file to Muse project using the Add Files for Upload option. Do not forget to change the .swf file name.
    <param name="SRC" value="assets/captivate6_file.swf">
    <embed src="assets/captivate6_file.swf" width="800" height="600"></embed>
    </object>
    Vinayak
    Apr 16, 2013 10:30 PM   in reply to Vinayak_Gupta
    I inserted the following HTML code that I gleaned from
    http://forums.adobe.com/message/5087131  -
    Re: Can't Place Captivate 6 swf or html5 File into Muse v3.2.
    The code is:
    <object width="1024" height="768"
    codebase="http://www.learndurkin.com/assets/infographics-history.swf/ version=8,0,0,0">
    <embed src="assets/captivate6_file.swf" width="1024" height="768"></embed>
    </object>
    I also uploaded the .swf file using the "Add File" function. When I publish, I get a blank white box with no video that plays. Any suggestions? Have I named the file incorrectly in the HTML code?
    I feel like an idiot. I keep pounding this day after day with no solution. Hope I am writing in the correct forum.
    Judy Durkin
    Hsinchu, TAiwan
    Apr 19, 2013 1:53 PM   in reply to judycanby
    The code is incorrect, leave the value for codebase attribute as is and modify the param src value with the file name (as highlighted under).
    </object>
    Vinayak
    Jun 8, 2013 6:04 AM   in reply to Vinayak_Gupta
    This was exactly the advice I needed to solve the same problem - thanks! Note to others - change the code to point to your actual SWF in BOTH places it occurs in that code. This is inelegant for an application that's supposed to be for non-coders, but I assume that Muse will evolve to accommodate SWFs better in the future.
    Aug 4, 2013 5:44 AM   in reply to Pasha Souvorin
    Hi everybody,
    thanks a lot for you great advice : it works !
    Just one more thing : how to stop the video ? I mean, add a control bar or so ?
    Sep 1, 2013 11:18 PM   in reply to labmicrobio
    Hi Vinayak, that works.  But I can also create an html5 file from captivate.  Is it possible to use this instead of the swf and what would be the advantages/disadvantages please?
    Sep 2, 2013 5:50 AM   in reply to estherau
    I don't see any dis-advantages if you go that way. You just need to make sure that all dependent files, if any, are uploaded to their relative location in order to get it working after publish.
    Vinayak
    Sep 2, 2013 4:34 PM   in reply to Vinayak_Gupta
    Muse user here - ie the no coding person who makes websites very occasionally.  So if you wouldn't mind, can you please post a little snippet of code to insert like you did for the SWF.
    Thanks.
    Sep 4, 2013 5:00 PM   in reply to estherau
    <param name="SRC" value="captivate6_file.htm">
    <embed src="captivate6_file.htm" width="800" height="600"></embed>
    </object>
    Am I close?  where the htm file is the html5 file created by captivate at save.
Bookmarked By (1)
