Can you please provide more info on what is happening? This article will tell you the type of info, that would be so very useful: http://forums.adobe.com/message/3220274#3220274
If you are getting any error messages, be sure to list those in complete detail.
While you are gathering the information to answer Hunt, some reading
Long File Names or odd characters cause problems
Read http://forums.adobe.com/thread/588273
And #4 http://forums.adobe.com/thread/666558
And This Message Thread http://forums.adobe.com/thread/665641
Things and Software to AVOID when authoring/burning a disc... says Encore, but also applies to Premiere Elements and disc burning
Start --> http://forums.adobe.com/thread/608660
#2 has WHY Explained http://forums.adobe.com/thread/607390
Plus http://forums.adobe.com/thread/562941
Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
Dear Mr Hunt,
I cannot put my document with all details in the mail on the forum. There seems no place for
So I send tehm to you.
I cannot burn my editied movie.
Adobe does the counting, but not starting the burning, I get an error.
Version Adobe Premiere 10
I didnot install Adobe Updates untill now
Operating System Windows XP, Home edition, Version 2002, Service Pack 3
Source Footage Camera DVC NV GS 230 Mini DV, AVI-film
Full text error: Faultnr. 2130970627
My actions to solve the problem:
Remove the Endmark of the edited movie
Edit a 1-minute version, dit not work either
Added NERO 6SE Burner, Inclusive Updates
Changed DVD Station to Plextor 712a, inclusive updates
Tried an Imagemap, and then burning, same negative result
Changed blank DVD media from Sony to TDK, not RW.
I have some times made a good DVD, untill the fault appeared.
I have no other software running
No third-party effectes of codecs installed
Computer: Intel ® Celeron ® CPU, 440 @2.000GHz, Clockspeed: 2.02 Ghz, 2.99 GB
I use no Mercury Playback Engine GPU Acceleration
The problem happens only with final output, not with previews
Can anyone help me?
Thanks a lot.
Bernard Bussemaker
Bernard,
That is a good start on the info, and is appreciated.
One quick question, regarding your computer - How much defragmented free space to you have on your HDD's (Hard Disc Drives), and where are your PrE Scratch Disks set (which HDD)?
Authoring a DVD can require quite a bit of HDD space (the location of the Scratch Disks), but even if one has plenty of defragmented space there, if their C:\ is nearly full, the authoring process can hang, or crash the program.
Good luck, and just add that information in your Reply, as you did with the file and other system info.
Try burning to disk rather than a DVD. This will create a folder containing subfolders VIDEO_TS and AUDIO_TS.
If you don't have a software DVD player, use the open source player "VLC". If you don't like installing additional software there is also a "portable version" (that makes no system changes, it just runs from its own folder).
Cheers,
Neale
Bernard,
While on the low side, if you have recently defragmented that 54.9GB of space, it should be adequate for such an operation.
When contemplating free-space, a few things to think about are:
You should have enough. The "rule of thumb" is between 40GB and 60GB, and you are at the high-end of that. Thank you for that info.
I think that Neale poses some good questions and suggestions.
North America
Asia Pacific
