remmy1234
Centering problem?
Feb 17, 2013 6:12 PM
Tags: #not #working #centering #window #align
I use illustrator CS4 and I've been having a problem with centering. I've tried to align the board using the window->align option but when I save it it still appears to be shoved up again the right side of the art board. I'll move it around to center it on the art board but the image in the layers palet still shows it as being smooshed up against the right side. I can't seem to fix it. Can anyone help?
    Feb 17, 2013 6:52 PM   in reply to remmy1234
    I can't make heads or tails of your post.
    Okay.
    The Align panel (Windows > Align) is for aligning objects, not the artboard. You want to center the artboard on screen? Is that correct? Have you tried View > Fit Artboard in Window? If so, what happens?
    Wait... I thought it was the "board" (as you put it) you were trying to center. So, what exactly is "shoved up again[st] the right side of the artboard"?
    Feb 18, 2013 4:37 AM   in reply to remmy1234
    If I am understanding you correctly, is this what you are seeing?
