Dear Sir / Madam
I will buy new computer with OS window 8 Pro (64bit).
So my existing CS5.5 is running under window XP in my old computer
Could you please advise about questions as below:
1. How to transfer CS5.5 to new computer with OS window 8 Pro (64bit)?
2. How to solve this error from running Adobe Illustrator CS5.1?
I am looking forward to your reply
Andrew
If you do not own discs for CS5.5, you can download CS5.5 trials versions to your new computer from the web site page linked below and then use your current serial number to activate it. You need to follow the Very Important Instructions to do that properly
http://prodesigntools.com/adobe-cs5-5-direct-download-links.html
You are allowed to maintain two machines with activated installations of Adobe software as long as they are not both using the same software at the same time. If you prefer to r
...Copy link to clipboard
You are allowed to maintain two machines with activated installations of Adobe software as long as they are not both using the same software at the same time. If you prefer to remove the software from the older machine you should deactivate it first (under the Help options) before uninstalling.
