Photoshop wont let me choose video animation?
Feb 18, 2013 2:02 AM
It automatically selects frame animation as soon as I open up timeline.
I have Photoshop CS6 Extended.
    Feb 18, 2013 4:48 AM   in reply to Zevoxa
    Would you mind providing the relevant details?
    Are you handling existing files or new ones?
    Feb 18, 2013 5:14 AM   in reply to Zevoxa
    For new ones you yourself should decide if timeline or frame animation are to be used.
    Could you please post a screenshot with the Timeline Panel visible?
    Feb 18, 2013 5:31 AM   in reply to Zevoxa
    Not what it looks like for me (apart from the … color theme) but why don’t you use »Convert to Video Timeline« from the Panel’s fly-out menu?
    Feb 18, 2013 5:38 AM   in reply to Zevoxa
    Are you sure you have Photoshop Extended (Photoshop > About Photoshop)?
  • JJMack
    Jan 9, 2006
    Feb 18, 2013 6:34 AM   in reply to c.pfaffenbichler
    Photoshop extended not required. Zevoxa try resetting you Photoshop preferences here is what I see.
    Feb 18, 2013 6:37 AM   in reply to JJMack
    The documentation states:
    Convert To Timeline Animation (Photoshop Extended)
    Converts a frame animation to timeline animation using keyframes to animate layer
    properties.
    But it’s certainly fine with me if it’s available in Standard.
  • JJMack
    Jan 9, 2006
    Feb 18, 2013 1:26 PM   in reply to c.pfaffenbichler
    Adobe documentation is in poor shape. Much work is needed in the documentation to make it up to date.  Adobe replaced Photoshop Animation Palette in CS6 with the Timeline Palette and added basic video support into standard Photoshop CS6
    Feb 18, 2013 11:31 PM   in reply to Zevoxa
    What is your OS?
  • JJMack
    Jan 9, 2006
    Feb 20, 2013 5:52 AM   in reply to Zevoxa
    Zevoxa wrote:
    I do have extended, but it wasn't let me choose because I was using the 64-bit version of Photoshop CS6. Apparently, it only has frame animation in the 64-bit version. It works fine in 32-bit.
    The screen capture you posted above does not look like CS6 extended for there are missing menu like 3D etc.  I have no problem with frame animation in CS6 Standard 64bit and 32bit???? I would think the same would be true with CS6 extended.
