Which computer is better for video editing?
Feb 18, 2013 4:50 AM
Tags: #settings #mac #audio #premiere #pc #computer #dvd #ae #bluray #multicam #after_effects_cs6
Hello guys,
I've started editing videos for DVDs and Blu-rays a few months ago, and I'd like to know which settings are better for me. I was wondering about buying a Mac, is it better than a PC with the same settings?
  • Jon-M-Spear
    Jan 27, 2006
    Feb 18, 2013 5:50 AM   in reply to GuiPaulino
    You're going to start a heated debate with that question, but I think you'll find that the majority of members are PC biased.
  • Jon-M-Spear
    Jan 27, 2006
    Feb 18, 2013 5:54 AM   in reply to Jon-M-Spear
    My ipad doesn't allow me to edit my entry...
    Look at www.ppbm5.com to see  PC comparison chart.
    Feb 18, 2013 6:00 AM   in reply to Jon-M-Spear
    Don't know where you are located, but this company is specialist in making PC's for Premiere Pro:
    http://www.adkvideoediting.com/
    The guys hang out here too, and help a lot of people with questions / issues.
    I must admit that I am a PC guy, and have build my own PC's, and have never had a mac.
    Others might have other point of views of course
    /Ulf
    Feb 18, 2013 6:04 AM   in reply to GuiPaulino
    Let's start by saying that you get the same results with a Mac as you do with a PC. The quality of the DVD or Blu-Ray does not depend on the type of computer used to write it to disk or play it back.
    A Mac of the equivalent power as a PC will cost much more. So, unless you are already a Mac user, there is no reason to switch. But if you are a Mac user, there is no reason (other than price) to change to a PC.
    The answer to the question you asked is: Whichever computer you are more comfortable with is the better one.
    The answers to the questions you probably should have asked require additional information: What settings are you using? Why are you unhappy with them?
    The default presets for exporting in Premiere Pro should do the trick for you, however, most people would probaby be better served by bringing the Premiere Pro project into Encore and letting Encore make the encoding decisions.
    Feb 18, 2013 6:29 AM   in reply to GuiPaulino
    No. I think you need to increase your RAM. There is no way that you can do much of anything with Windows 7 if you only have 4G of RAM.  You should have 2G for every core - at a minimum.
    Feb 18, 2013 8:13 AM   in reply to Steven L. Gotz
    Actually, it does seem that the Adobe suite simply runs better on the PC than on a Mac.  This I've seen even Mac users admit.  So there is a second reason.
    Feb 18, 2013 8:19 AM   in reply to GuiPaulino
    I was told I need improve only my video board
    That's probably the only thing you don't really need to replace.  Your CPU of choice is pretty far from ideal with modern HD media.  You should seriously consider an Intel i7 3770K, which also means a new motherboard.  And as mentioned, a minimum of 8GB of memory, with 16 being the better option.
    Your current video card will work, but if you have enough money left after the above purchases, then you can think about upgrading it.
    Feb 18, 2013 9:26 AM   in reply to GuiPaulino
    Whichever way you turn it, PC or MAC is your choice, but what you currently have, a Phemon II X6 with 4 GB memory and a GT520 is dead slow. It is definitely amongst the 10% slowest PC on our benchmark test, more than 10 times slower than a fast system and cannot be upgraded economically.
    Your choices are simple: Get a completely new system, based on an Intel CPU. Think along these lines, i7-3xxx quad or hexa core CPU, 16+ GB memory, GTX 660+ video card and the other components to go with it.
    Feb 18, 2013 9:43 AM   in reply to GuiPaulino
    [moved to hardware forum]
    Feb 18, 2013 10:08 AM   in reply to GuiPaulino
    I do like Steven's answers above and my own testing running Windows 7 and OSX 10.8.2 confirms results are quite similar between two identical configurations, but with the Windows platform you do have in addition to Steven's comments.:
    • A lot more choices in configurations.
    • You can very simply and safely overclock a PC.
    • Recent history shows Apple is not upgrading the Mac Pro line and even has downgraded their Final Cut Pro.
