Crop help !
Feb 18, 2013 7:44 AM
I would very much appreciate help on the following. I edit medical clips that contain patient information and technical details on the edge of the frame. I used Premiere 4 through 6 to crop that information out and keep only the images, and loose all the peripheral information. I now use Pr CS6 (Win 7 pro). In the older version there was a transformation called "PAN" that allowed to crop and delete what is outside the cropped aread. For instance the original clip is 800 by 600 pixel, but I trimmed 139 pixels from the left, 47 from the top, 240 from the right and 123 from the bottom. THose are typical numbers but they vary from clip to clip as the region of interest varies from clip to clip. I want to export a clip that is (800-[139+240]) pixel wide and (600-[47 + 123]) high.
I can seem to find out how to do this in CS6.
I do not knwo ahead of time what the final output size will be, i discover this as I edit each clip.
Thanks for suggestions (in simple terms :S)
    Feb 18, 2013 8:06 AM   in reply to fetusticianpj
    You can use the Crop feature on the Source tab of the Export Settings dialog.
    Feb 18, 2013 8:22 AM   in reply to fetusticianpj
    You'll have to do the math to change the export resolution.
    Feb 18, 2013 9:03 AM   in reply to fetusticianpj
    Don't use Match Sequence Settings.
    If the dimensions don't allow the change, you may need a different Format.  For example, DV is restricted and can only be 720 x 480.
    Feb 18, 2013 11:00 AM   in reply to fetusticianpj
    What the export to be used for?
    Feb 18, 2013 5:00 PM   in reply to fetusticianpj
    Try H.264.  It's pretty flexible.
    Feb 19, 2013 9:19 AM   in reply to fetusticianpj
    You're welcome.
