Good Day all
When I Import an asset into encore and insert into timeline the audio is shorter than the video. I Exported in PPro cs6 using the preset mpeg dvd ,with multiplexer set to dvd, which only gives me one mpeg file.
If I delete the .xmpses and .xmp files of the exported mpeg file before importing into encore it rewrites the files correctly
Is there a way to fix this?
I've seen this same issue on the forum a couple of times in recent weeks. Some kind of bug with the Multiplexed content. As Stan suggested, do NOT use multiplexing - that is an incorrect workflow for Encore. I know you meant well, but besides changing the bit rate if need be, the presets work great and have the right settings for Encore-compliant file output by default.
The normal workflow from AME is to set Multiplexing to NONE, which results in the two files, .m2v video and .wav audio (uncompressed). This is the DEFAULT. You also get the other bits you mentioned which carry info for the chapter markers from Premiere. The only thing you might change in the export settings is the bitrate for longer projects so they fit the disc.
In Encore, use File > Import > As Timeline and select the .m2v and .wav files together. This will automatically import the chapter marks (if set in Premiere) as well. The video will NOT need to be transcoded, and the uncompressed audio will be transcoded directly to high quality Dolby AC-3, skipping that MPEG "middle man". That takes just moments.
Jeff Pulera
Safe Harbor Computers
Another helpful tip - once you've imported the .m2v and .wav files into Encore and you're putting your menus and stuff together, perhaps you notice a problem with the audio that you wish you could fix - if it didn't mean starting all over.
Well good news - in Premiere, make the fix to your sound (adjust volume, add a crossfade, fix a glitch, whatever) and then simply export a new .wav file (48k stereo, default usually), no video. In Encore Project window, highlight the original .wav file, and use File > Replace Asset to locate NEW audio clip and replace. No need to re-encode the video again! Audio-only exports are super-quick from Premiere. I actually did this 3 times on my latest 2-hour school musical. Kept finding more "little things" in the audio when proofing DVDs, that I had missed earlier. Of course, do not do anything in your Premiere project that changes the timing, or this is not going to fly.
Jeff Pulera
Safe Harbor
One more thing! I often forget this because it is NEW with CS6. When exporting MPEG-2 DVD from AME, the Audio options used to be PCM or MPEG (there may have been a Dolby option, but after trial it required buying a $300 plug-in). CS6 now offers the Dolby stereo as an option, so rather than creating .m2v and .wav files, the audio CAN be AC-3 right from AME, and then there is NO transcoding in Encore, since the audio and video are compliant and DVD-ready
Thanks again
Jeff Pulera
North America
Asia Pacific
