I am having trouble with Adoby Illustrator "copy" and "paste" functions. It take a very long time (as long as 30 min) to copy a simple line and even longer to paste it. This probles is getting worse. My file size is unusual as well. A comparable file is 155k and this one is up to 65 meg and growing.
What is wrong and how do I fix it?
Do you have a bunch of repeating graphics in your symbols panel and/or your Brushes panel? If so, this is a known issue, there is a solution but it's a bit to spell out without being sure it's the problem. Take a look, let us know. The problem will be obvious, probably lots of ladybugs...
Michael Riordan
Adobe Certified Instructor
Digital DesignLab
Just found Adobe's write up, which makes it a whole lot easier on me
. Here are the steps you need to follow:
http://helpx.adobe.com/illustrator/kb/copy-paste-artwork-slow-or.html
Location of prefs file:
http://helpx.adobe.com/illustrator/kb/preference-file-location-illustr ator.html
How were you able to try the solutions if you did not know where the prefs file is???
Try again, and actaully what they labeled as solution 2 & 3 need to both be done to fix this. In the meantime do NOT copy anything from the infected file to any other file, or this will spread like wildfire to all your files.
I'm guessing you are on a mac with a fairly recent version of the operating system. Apple recentlytook to hiding the library folder. Toaccess it, you now need to hold down the option key when you access the go menu. Do that and the Library folderwill magically appear. Then you can look inside for the illustrator prefs.
hope that helps,
Michael Riordan
Digital DesignLab
File is still 7 meg (should be 155k)
Did you perchance save your file with an unnecessary colour profile?
Did you embed an image when you could have linked it?
Did you save the file with pdf compatability when there was no need to?
Things like that can balloon file sizes; I suspect the colour profile.
Try a Save As (or Save a Copy), checking only Use Compression and see what happens to file size and speed of saving.
Try trashing unused colour swatches and then save the file under a new name.
Any change in file size?
There is something in there that is making your file absurdly large. I’m convinced that’s what is crippling your machine.
If you can copy and paste stuff into a new document (bit by bit) it may help. Use Cmd+F for pasting to preserve positioning.
If that doesn't happen to all your files, but only to one file, then this file seems seriously broken.
CS3 doesn't offer simple fixes for this. Maybe CS6 with its repair routines can fix your file and it can then be saved down to CS3 again. You could try and use the Demo version or maybe someone will try for you if you post the file.
North America
Asia Pacific
