From using premiere pro CS 5.5 I am trying to output a DVD. I am using the settings of MPEG2 DVD. Is there a way to export doing 1920 x 1080. When playing the footage on DVD (via encore) the quality is not that great as we are playing the DVD on a 32" screen. hence why the settings 720 x 576 is not that great, just trying to output a way so that a DVD is playing with good quality im currently outputting using MPEG DVD (720 X 576 ) but im trying to output it to 1920 x 1080. i am trying to output to encore, where i can build a dvd and burn it but the quality is not great because of the default settings
Hi Dominic,
Some people have reported that they do burn Blu-ray content onto DVD media, but note these discs will NOT play in a DVD player, must be a Blu-ray player, and capacity is maybe 10-15 minutes or so. This is not something you would distribute, just for personal use if it works for you.
Jeff Pulera
Safe Harbor Computers
Thats what I thought really. Is there any other method making a DVD in 1920 x 1080? Whether that be making it a MP4 as this size? The quality is ok, but im after something a bit better. Playing the DVD that I have made on a 32" screen, you can defo tell that it has ben outputted as 720 x 576. Many thanks
As Harm said, DVD is a very specific specification. For PAL, that is MPEG-2 at 720x576, and NTSC is 720x480. Nothing else will do, these are the only formats a DVD player will play.
You can either create a proper Blu-ray disc, using MPEG-2 or H.264 for Blu-ray, or experiment with burning those files to a blank DVD, but again, those WILL NOT PLAY on a DVD player, it won't recognize the material and does not have the circuitry to play HD files. Since you will need to have a Blu-ray player either way, I would recommend just burning to BD if you want HD playback from disc.
Another option is to get a "Media Player", such as Western Digital WDTV or Roku or many others. Most of these are well under $100 and will play HD files from your USB drive or thumb drive, out to an HD display via HDMI. Then you don't need a Blu-ray player or BD discs or burner. Just create the video clips and put them on a USB stick. I should note that my Sony BD player also has a USB port and will do this as well.
Jeff
North America
Asia Pacific
