David_8-)
Dreamweaver CS6 - locks up when connecting to server - sftp
Feb 19, 2013 5:39 PM
I am using Dreamweaver CS6 on Windows 7  64bit which is connected to a remote server using sftp.  Most of the time connecting to the server has been fine but now Dreamweaver has started locking up when I use the Put command.   According to the log the process times out but if this is the case surely the program would still be operational.   However, when this occurs Dreamweaver is unusable and the task manager has to be used to force the program to close.  When it happens regularly (as it is today) the program becomes unusable. The files I have been uploading when this occured today were between 5 and 20KB's.
Does anyone know how to fix this problem.
    Feb 20, 2013 3:32 AM   in reply to David_8-)
    Use Check-in/Check-out while transferring. This can be enabled as follows:
    In the site settings dialog, go to advanced tab and check the checkbox "Enable check-in/check-out". Give a name and a user-id as well. Save the settings now and you can do a get/put or check-in/check-out and confirm does it works or not.
    Harshit
