mariechristinemiquel
Help with CS2 9.0.2 crashes on MacOS X 10.5.8?
Feb 20, 2013 9:06 AM
Tags: #photoshop #crash
Can anyone help with CS2 crashing all the time after 10 sec on Mac OS X 10.5.8?
Here is the report,
I know there has been somewhat similar questions/answers, but I think my problem is different.
If anyone can make sense of the following and let me know if I can go back to the previous configuration when all worked smoothly, or if I can fix the problem, I would be very grateful.
Thank you very much.
Process:         Adobe Photoshop CS2 [562]
Path: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2
Identifier: com.adobe.Photoshop
Version:         9.0.2 (9.0.2x312 [20060822.902x312 02:00:00 cutoff]9.0.2x311) (9.0.2)
Code Type:       PPC (Translated)
Parent Process: launchd [103]
Interval Since Last Report:          2655 sec
Crashes Since Last Report:           2
Per-App Interval Since Last Report:  690 sec
Per-App Crashes Since Last Report:   2
Date/Time: 2013-02-20 15:07:05.096 +0100
OS Version:      Mac OS X 10.5.8 (9L31a)
Report Version:  6
Anonymous UUID: A175C8E9-928A-4EAD-8BA4-07AED6AAD0B7
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000ffeffdff
Crashed Thread:  0
Thread 0 Crashed:
0   translate                            0xb80bcd58 0xb8000000 + 773464
1   translate                            0xb80b7007 0xb8000000 + 749575
2   translate                            0xb80d49c0 0xb8000000 + 870848
3   translate                            0xb813ce79 spin_lock_wrapper + 1981
4   translate                            0xb8011b64 0xb8000000 + 72548
Thread 1:
0   ???                                     0x800bc166 0 + 2148254054
1   ???                                     0x800c395c 0 + 2148284764
2   translate                            0xb818b6ea CallPPCFunctionAtAddressInt + 202886
3   ???                                     0x800ed055 0 + 2148454485
4   ???                                     0x800ecf12 0 + 2148454162
Thread 2:
0   translate                            0xb81529ef spin_lock_wrapper + 90931
1   translate                            0xb8183633 CallPPCFunctionAtAddressInt + 169935
2   translate                            0xb81861e2 CallPPCFunctionAtAddressInt + 181118
3   translate                            0xb80dfb0b 0xb8000000 + 916235
4   ???                                     0x812cbac6 0 + 2167192262
Thread 3:
0   translate                            0xb8152863 spin_lock_wrapper + 90535
1   translate                            0xb816e79d CallPPCFunctionAtAddressInt + 84281
2   translate                            0xb80dfb0b 0xb8000000 + 916235
3   ???                                     0x81e6f9f6 0 + 2179398134
Thread 4:
Thread 5:
0   translate                            0xb815289e spin_lock_wrapper + 90594
1   translate                            0xb816e8a7 CallPPCFunctionAtAddressInt + 84547
3   ???                                     0x81e91786 0 + 2179536774
Thread 6:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000008  ebx: 0xb80bcd30  ecx: 0xffeffdf7  edx: 0x00000003
  edi: 0xffeffdff  esi: 0x8030be60  ebp: 0xb7fffa08  esp: 0xb7fff9d0
   ss: 0x0000001f  efl: 0x00010206  eip: 0xb80bcd58   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0xffeffdff
Binary Images:
0xb8000000 - 0xb81d7fe7 translate ??? (???) /usr/libexec/oah/translate
Translated Code Information:
Rosetta Version: 21.03
Args:   /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 -psn_0_204850
Exception: EXC_BAD_ACCESS (0x0001)
Fullscreen: Activated
Thread 0: (0xb009a83c, 0xb81529ef)
0x00000000: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 :  + 0
0x94d96fe4: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : _TS_exception_listener_thread + 112
0x90232074: /usr/lib/libSystem.B.dylib : __pthread_body + 40
PPC Thread State
srr0: 0x00000000       srr1: 0x00000000                                vrsave: 0x00000000
cr:  0xXXXXXXXX             xer: 0x20000000                     lr: 0x901a7fa0                       ctr: 0x901a1070
r00: 0xffffffe1            r01: 0xf0080de0         r02: 0xa0088fbc         r03: 0x0395c600
r04: 0x00000002        r05: 0x00000000        r06: 0x00000054        r07: 0x00005007
r08: 0x00000000        r09: 0x00000000        r10: 0x00000000        r11: 0xa008868c
r12: 0x901a1070        r13: 0x00000000        r14: 0x00000000        r15: 0x00000000
r16: 0x00000000        r17: 0x00000000        r18: 0x00000000        r19: 0x00000000
r20: 0x00000000        r21: 0x00000000        r22: 0x00000000        r23: 0x00000000
r24: 0x0395c600        r25: 0x00000054        r26: 0x00005007        r27: 0x00000000
r28: 0x00000000        r29: 0x00000002        r30: 0x00000002        r31: 0x94d96f7c
Thread 1: (0xb011ce24, 0xb8152863)
0x94dcd79c: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : _MPWaitOnSemaphore + 40
0x10c5b428: /Applications/Adobe Photoshop CS2/Modules externes/Extensions/Support multiprocesseur.plugin/Contents/MacOS/MultiProcessor Support : ThreadFunction(void*) + 64
0x94db9388: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : _PrivateMPEntryPoint + 80
PPC Thread State
cr:  0xXXXXXXXX             xer: 0x20000000                     lr: 0x94dcd7e0                      ctr: 0x901a10e0
r00: 0xffffffda            r01: 0xf0101da0         r02: 0x10a10bf0         r03: 0x00005307
r04: 0x7fffffff             r05: 0x00000000        r06: 0x00000000        r07: 0x00000000
r08: 0x147f2017         r09: 0x03f97200         r10: 0x147f200f         r11: 0xa0088a78
r12: 0x901a10e0         r13: 0x00000000        r14: 0x00000000        r15: 0x00000000
r24: 0x00000000        r25: 0x00000000        r26: 0x00000000        r27: 0x10c5b3fc
r28: 0x80000000        r29: 0x7fffffff             r30: 0x00000000        r31: 0x94dcd780
Thread 2: (0xb02a283c, 0xb81529ef)
0x1093cf30: No symbol
PPC Thread State
cr:  0xXXXXXXXX             xer: 0x00000000                     lr: 0x901a7fa0                       ctr: 0x901a1070
r00: 0xffffffe1            r01: 0xf0284d00         r02: 0x1093e130        r03: 0x03f73a00
r04: 0x00000002        r05: 0x00000000        r06: 0x00002000        r07: 0x00007c03
r08: 0x00000014        r09: 0x00000000        r10: 0x93f1ec48         r11: 0xa008868c
r24: 0x03f73a00         r25: 0x00002000        r26: 0x00007c03        r27: 0x00000014
r28: 0x00000000        r29: 0x00000002        r30: 0x00000002        r31: 0x1093cd20
Thread 3: Crashed (0xb7fff9d0, 0xb80bcd58)
0x004f5a64: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : SubViewContainingPoint(TView*, VPoint const&) + 1111520
0x004f56a0: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : SubViewContainingPoint(TView*, VPoint const&) + 1110556
0x004f4ab8: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : SubViewContainingPoint(TView*, VPoint const&) + 1107508
0x00836970: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : XPEPLaunch::IsRunning(unsigned short const*) + 118596
0x00067370: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : LookupErrString(short, short, ZString&) + 246964
0x0032e9e8: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : NewObjectBySignature(unsigned long, CStr255 const&) + 8440
0x0080137c: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : IsShowingAlert() + 60560
0x008012f8: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : IsShowingAlert() + 60428
0x00801d88: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : IsShowingAlert() + 63132
0x00801250: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : IsShowingAlert() + 60260
0x007ef0e0: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : InitUPrinting() + 381924
0x00064a18: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : LookupErrString(short, short, ZString&) + 236380
0x007eaa2c: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : InitUPrinting() + 363824
0x00838bb8: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : PercentageWindowVisible(TWindow*) + 6864
0x007f1d1c: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : InitUPrinting() + 393248
0x00003858: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : dyld_stub_binding_helper + 1288
0x00003530: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : dyld_stub_binding_helper + 480
0x000032c4: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : ___code_start__ + 512
0x000030f4: /Applications/Adobe Photoshop CS2/Adobe Photoshop CS2.app/Contents/MacOS/Adobe Photoshop CS2 : ___code_start__ + 48
PPC Thread State
cr:  0xXXXXXXXX             xer: 0x00000000                     lr: 0x004f5a64                       ctr: 0x901ab734
r00: 0x00000001        r01: 0xbfffe670          r02: 0x00000000        r03: 0xffeffdf7
r04: 0x0ab158c0         r05: 0x00ffe740          r06: 0x00000000        r07: 0x0e7cc3a0
r08: 0x14efc080         r09: 0x00000002        r10: 0x00000001        r11: 0xa0087db8
r12: 0x901ab734        r13: 0x00000000        r14: 0x0143edfc         r15: 0x00000016
r16: 0x00000000        r17: 0xbfffe8f8           r18: 0xbfffe8ec           r19: 0xbfffe8d8
r20: 0xbfffe8d4          r21: 0xbfffe8cc           r22: 0x00000000        r23: 0x0efc04e0
r24: 0x00000007        r25: 0x01174158        r26: 0x01437b2c        r27: 0x0e782de0
r28: 0x0143ee48         r29: 0x0e7cc3b0         r30: 0x01440000        r31: 0x00000000
Thread 4: (0xb0220e20, 0xb815289e)
0x901e41d8: /usr/lib/libSystem.B.dylib : __pthread_cond_wait + 1260
0x94d99944: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : _TSWaitOnConditionTimedRelative + 244
0x94d99718: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : _TSWaitOnSemaphoreCommon + 432
0x94d993dc: /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore : AsyncFileThread(void*) + 68
PPC Thread State
cr:  0xXXXXXXXX             xer: 0x20000000                     lr: 0x901e4218                      ctr: 0x901a10f0
r00: 0xffffffd9            r01: 0xf0203cb0         r02: 0xa008353c         r03: 0x00005e03
r04: 0x00005d03        r05: 0x0000003c        r06: 0x00000000        r07: 0x00000000
r08: 0x00013c00        r09: 0x00000001        r10: 0xf0203e68         r11: 0xa0088a74
r12: 0x901a10f0         r13: 0x00000000        r14: 0x00000000        r15: 0x00000000
r20: 0x00000000        r21: 0x94e79570        r22: 0x94e79570        r23: 0x00000000
r24: 0x00000000        r25: 0x00000001        r26: 0xf0203e68         r27: 0xa0083d00
r28: 0xa07cfa4c          r29: 0xa008353c         r30: 0xa07cfa80          r31: 0x901e3d00
Thread 5: (0xb019ee24, 0xb8152863)
0x018ecf90: @executable_path/../Frameworks/AdobeACE.framework/Versions/A/AdobeACE : ACESemaphoreList::Wait(unsigned long) + 36
0x018ed1dc: @executable_path/../Frameworks/AdobeACE.framework/Versions/A/AdobeACE : ACEMPThread::Task() + 76
0x018ecba0: @executable_path/../Frameworks/AdobeACE.framework/Versions/A/AdobeACE : _TaskGlue + 28
PPC Thread State
cr:  0xXXXXXXXX             xer: 0x00000000                     lr: 0x94dcd7e0                      ctr: 0x901a10e0
r00: 0xffffffda            r01: 0xf0182d20         r02: 0x1173af10         r03: 0x00005803
r08: 0x00003f18         r09: 0x03f97200         r10: 0x00000000        r11: 0xa0088a78
r24: 0x00000000        r25: 0x00000000        r26: 0x00000000        r27: 0x00000000
r28: 0x00000000        r29: 0x7fffffff             r30: 0x00000000        r31: 0x94dcd780
    Feb 20, 2013 9:58 AM   in reply to mariechristinemiquel
    From a previous post:
    You're running old PowerPC code under emulation on an Intel processor.
    Apple's emulator has a lot of bugs, and Apple has stopped shipping it and will not be fixing bugs in their emulator.
    The crash report just indicates that there is a bug in the emulator - we can't tell anything else from it.
    Your best option is to upgrade to a recent version of Photoshop that is Intel native (CS3 or later).
