toolleather1
Adobe Illustrator 6 keeps freezing on every computer I use.
Feb 20, 2013 6:28 PM
I'm using Adobe Illustrator 6 at school (new IMacs) and at home  Macbook pro and IMac 2009, and when using every computer illustrator freezes using the effects feature, so I have to force quit and start again with no avail.  What could be the problem?  All software is up to date, is anyone else having this issue?
    Feb 22, 2013 7:47 AM   in reply to toolleather1
    Some effects are very processor intensive and could take a while. It's also possible to crash Illustrator if you accidentally double up effects when all you intended to do was edit the first effect.
    [ signature removed by forum host - advertising is not permitted ]
    Feb 22, 2013 7:46 AM   in reply to toolleather1
    Sounds like you are applying effect upon effect in a combination that is just too complex to render. Illustrator will try, but in reality can't do what you are attempting. I see this a lot, especially with 3D.
    What were you trying to do, what effects were you applying?
    If you applied the pattern as a fill to a shape and then tried applying the 3D, that's your issue. If you save the pattern as a symbol and map it to the surface of your 3D object, you should be okay. make sure the flat vectors are filled with a solid color.
    Happy to help. Good luck.
