crashbdx
Dreamweaver crash regularly when link an img
Feb 20, 2013 10:52 PM
when i work on dreamweaver in code writting mode and link an img starting writing <img src etc choose my image and when validate, often after that dreamwearver don't respond anymore and i have to restart it.. it's really hard to work correctly like that... anyone know a solution for it ?
Thanks in advance
Im on windows 7 64Bits
    Feb 21, 2013 2:45 AM   in reply to crashbdx
    HI,
    Which version of Dreamweaver are you using?
    Preran
    Feb 21, 2013 10:56 AM   in reply to crashbdx
    crashbdx wrote:
    cs6 12.2 Build 6006 from adobe cloud
    Navigate to Control Panel -> Action Center -> Problems to report -> Find the latest Crash date -> View a temporary copy of these files.
    Zip this folder and send to Adobe as a Bug.
    I thing they will respond soon.
    Feb 21, 2013 11:08 AM   in reply to crashbdx
    after I changed to WIN 7 recently, I had some computer crashes too. The affected applications I installed again. From then on, everything runs like a charm. So you should try this too.
    On the other hand, perhaps you can send us the link to the relevant page, so that we could try it out with our DW.
    Hans-Günter
    Feb 22, 2013 12:12 AM   in reply to crashbdx
    This needs to be done on Windows not in Dreamweaver.
    Go to Start -> Control Panel -> Action Center -> Problems to report -> Find the latest Crash date -> View a temporary copy of these files
    Feb 23, 2013 3:34 AM   in reply to crashbdx
    I stil think it is better to uninstall or remove the program and reinstall it before you go into the depths of WIN. So it will be configured correctly in your system. As I said above, doing this, my DW "runs like a charm" AND that even though there are two version running in parallel.
    When it's still crashing I recommend the following steps (my hints are translated from my German WIN):
    1.Adobes remove program. It it "answers" all is already deleted. So you should have a look at:
    2.Windows Control Panel (Systemsteuerung). If no success, use:
    3.File manager: Search in your Adobe directory for your CS6, maybe there are remaining some files of it. And after that go to
    4.WIN regedit.exe (the sledgehammer approach): If DW has clearly left its mark, you will find them there. Use search function, BUT be careful by deleting. in any case save your regedit first!
    Hans-Günter
    Feb 23, 2013 3:36 AM   in reply to crashbdx
    Bonjour,
    ce qui est peut-être même pu essayer, s'il vous plaît envoyez-nous un lien vers le site concerné, pour expérimenter avec nos DW.
    Hans-Günter
    Feb 24, 2013 11:06 AM   in reply to crashbdx
    Does DW crash with all sites or just this one?
    As a test, create a new page  -- File > New > Blank HTML > Layout > choose a layout from the 3rd panel.  Hit Create button.
    SaveAs test.html
    Insert an image.
    Did DW crash?
    Nancy O.
