Hello,
I'm pretty new to After Effects, so this may be an easy fix. I first started out with a white solid as a floor and then a 3d wall. I've got the camera first stare out into nothing to show another wall fly, then have it wrap around the wall to show the floor and other existing wall, and then going onward to the other side of the wall to show it explode. Here are the screen shots(the end of the animation is at the top, so go from the bottom up):
Basically, here's my problem: I've only messed with the Y rotation of the camera to get it showing the floor and pre-existing wall for most of the shot. Though, the camera is spinning around in all different directions and I'm not sure how to fix it. Also, at the beginning, makes the floor and wall all stretched and such. Any help with this would be fantastic!
Thanks!
Basically, you're having difficulties because you are approaching the animation of the camera incorrectly. You're using a two node camera, which has a physical position and a Point Of Interest (POI). The POI is generally animated with the position paramter to guide the direction of the camera as it moves in space.
You're only animating the camera's position and Y rotation, without changing the camera's POI, which can have unpredictable results. You're fighting with the camera's built-in "desire" to point toward the POI.
Start with the basics and learn how to approach camera animation within AE. Once you get the hang of it you'll find it's quite straightforward, if a little eccentric.
This link points to the first part of a 3-part tutorial series on 3D camera in AE and how to build a camera rig. You'll find it helpful.
North America
Asia Pacific
