How do you smooth the edges of an image
Feb 21, 2013 3:05 AM
How do you smooth the edges of an image, like the question mark edges?
Regards Peter
  • 99jon
    Jan 6, 2010
    Feb 21, 2013 3:20 AM   in reply to peterbennetts43
    You could duplicate the image (Ctrl+J)
    Then apply some blur (Filter >> Blur >>Gaussian Blur)
    That will blur the whole image so apply a layer mask and invert (press Ctrl+I)
    Set foreground color chip to white and select the brush and choose a very small diameter. Then brush gently over the edges to reveal the blur.
    You can switch the color chip to black to undo a mistake then back to white to continue.
    Alternatively simply select the blur tool from the tools pallet (keep pressing the R key to tab tool choices) and blur the edges as wanted. It’s a little more crude but will probably do the job.
  • 99jon
    Jan 6, 2010
    Feb 21, 2013 4:01 AM   in reply to peterbennetts43
    Bottom left of tools pallet. Press the D key for the default black & white.
  • 99jon
    Jan 6, 2010
    Feb 21, 2013 4:12 AM   in reply to peterbennetts43
    Can you see the layers pallet (if not use the menu: Window >> Layers)
    You click on the small circle symbol to add a layer mask.
  • 99jon
    Jan 6, 2010
    Feb 21, 2013 4:31 AM   in reply to peterbennetts43
    I used the first method with the layer mask. That also means you can reduce the opacity if you wish a little of the original rough edge to show through the blur effect.
