linksdesign
Detail page in Master Detail set displaying info from wrong row in mySQL
Feb 21, 2013 4:20 AM
Tags: #wrong #database #mysql #master #set #row #detail
I have set up a Master Detail page set using a mySQL relational database. There are three tables in the database: provider, benefit and category. The Master page works fine, displaying the information I've chosenfrom each of the tables. The Advanced Recordset on the Master page is as follows:
SELECT benefit.BenefitName, benefit.BenefitDesc, benefit.MinMembers, benefit.MaxMembers, benefit.SpecialTerms, benefit.Connectivity, benefit.OnlineProcessing, benefit.OnlineTutorial, benefit.Contact, provider.Company, provider.CompanyInfo, provider.LogoL, provider.LogoS, category.Category, benefit.BenefitID
FROM benefit, provider, category
WHERE provider.ProviderID = benefit.ProviderID AND category.CategoryID = benefit.CategoryID
ORDER BY provider.Company
The Detail page should show information pulled from both the benefit and provider tables. However, although the benefit details display correctly, the details coming from the provider tables only ever show the info from the first row in the table. The recordset on the Detail page (autogenerated by Dreamweaver) is as follows:
SELECT benefit.BenefitName, benefit.BenefitDesc, benefit.MinMembers, benefit.MaxMembers, benefit.SpecialTerms, benefit.Connectivity, benefit.OnlineProcessing, benefit.OnlineTutorial, benefit.Contact, provider.Company, provider.CompanyInfo, provider.LogoL, provider.LogoS, category.Category, benefit.BenefitID, provider.ProviderID
WHERE BenefitID = colname
I'm by no means an expert with PHP or mySQL, but having done a lot of searching online I think this is something to do with needing to add another parameter manually on the Detail page, but I'm not sure how or where to do it. Can anyone help? I need to get the site live in the next few days and it's driving me nuts!
Margaret
    Feb 21, 2013 11:51 AM   in reply to linksdesign
    That recordset SQL is wrong - it is missing the joins for the tables that you showed in the first SELECT statement in your post - so your recordset is returning a cartesan product. Scan the entire contents of the page and make sure that you don't have duplicate recordset code - DW sometimes does this. Then you will need to fix your SQL so that the tables are joined properly.
