I'm new to Encore. I built my project this week with navigation menu for my 7 videos.
My videos are not big in general. If I leave Encore do transcode for my porject, this will create huge files for my videos that would
take up a lot of spaces on DVD.
I started it over. I imported my video. Right click on the file to edit Transcode setting. I played with Min., Traget, Max Bitrate.
If I lower anyone of them, I would reduce my file sizes but the quality are not great. I need to keep adjusting the bitrate and preview
my project and see if the video quality is acceptable.
My question is. Are there anyway to transcode small portion of my video. I don't need to wait until the whole process is finished.
I don't seem to find such option to do that. I'm forced to transcode my entire video before I turn my video to timeline and do a test.
Also, am I on the right track to minmize my transcoded video's filesizes?
Thanks.
Thanks John,
I'm new to Enocre. PPro you referred to, is that Adobe Premiere. I have my videos already in MP4 formats. I just need to put them all togehter with menu on DVD. From my experience, default automatic transcode in Encore will use a high quality setting which would generate huge transcoded file sizes. This is not what I want.
I have 7 videos. They all are MP4 formats. They are about 14min, 22min or 25min. Nothing long and big. One MP4 video is about 127MB. After using Encore automatic transcoding, the trancoded files (within the folder) generated about 654MB. This is too big for me.
I'm changing transcode setting and changing Bitrate quality to min: 3, target: 4, max: 4.
Then, transcoded video file sizes become smaller.
This is my question. Am I on the right track to do this? Thanks.
Hi, I'm new to video stuff. What's DL stand for? I bascially have 7 MP4 videos. I just have the files. I don't have a working files for them. I use FinalCut but I'm thinking to use Premiere for my next simple video and try.
Since my first trail generated too hugh transcoded files, I changed transcode settings by right click on the untranscoded video. Changed the transcode setting. (Bitrate quality)
Min Bitrate: 3, Target: 4, Max: 4
The result is I got smaller files but the qualities wouldn't be as good as the automatic transcoding.
Am I on the right track to do that?
Thanks.
That is not correct. It will select transcode settings to fit the material on disk. You appear to have something about 2 hours plus, so the quality may suffer, but it may be okay.
Exporting from FCP as mp4 is not the best workflow. You are compressing, then sending to Encore for it to be transcoded to DVD format.
Can I confirm something from you?
Default automaic transcode in Encore will use the best quality setting to fit all videos on disk. My situation is I have 7 videos. They eventually take up about 4GB of space on DVD.
Let's say, now I have 3 more videos (10 videos in total), default setting would adjust transcode quality accordingly to fit everything on DVD. Is this the case?
The reason I'm so concered is my 7 videos are not HD. They are not long. They still take up almost entire DVD. What if I have a few HD videos to put on DVD? Would that run out of space in that situation?
I generally export my FCP project to QuickTime movies. Not sure if that's a good format or not. The file sizes are generally smaller than MP4 in my situaiton.
7 MP4 videos are given to me so I didn't really output from any sources.
Thanks.
Yes.
See John's answer above. DVD will not take HD. The HD must be downrezzed/transcoded to SD. It won't take any more or less space than SD footage. The amount of motion etc in the footage is more the issue. Some video will look okay at a datarate that will look terrible for other material.
The best workflow is either an uncompressed/minimally compressed export to Encore for final transcoding to DVD format, or export the original to DVD format. QT can be okay if uncompressed. MP4 is not a good option as an intermediate.
Not much you can do with that if you don't have access to better source. Bring into Encore with automatic settings is probably okay.
Your main challenge is going to be how much video you can get on the disk before it starts to look bad.
I'm having the same concerns as commonguy101
I'm building the video in Premiere Pro CS5 and creating DVDs in Encore CS5.
All video is a combination of SD video and still photos. There is an extra audio track (mp3) of music that runs the length of each clip.
Total duration is approximately 75 minutes
Hi Stan,
I did a quick test at work today.
7 videos were transcoded with Automatic setting before. Then, I create 3 more buttons
and import 3 more videos. After all transcodes are done, check Build panel everything still fit on DVD. Didn't burn anything on the disk. I'm sure that's what you said. Leave automatic setting for Encore will determine the best transcode quality for my DVD.
That's what Adobe Help says too:
For assets with the Automatic designation, Encore determines the optimal settings for transcoding. Encore bases these settings on the number, length, and size of the assets and the available disc space. (See About bit budgeting.) You can override the Automatic data rate setting by specifying the Maximum Audio/Video Bitrate on the Advanced tab of the Project Settings dialog box. Alternatively, you can specify a transcode preset for any of these assets.
That's good. The only downside is the disk spaces on my hard drive.
Thanks.
Before you transcode anything using automatic, you should create all menus, motion, etc and add all videos to the project. If you transcode some of the videos before this, Encore calculates to make the disc full with only those. If it is not full, it is because Encore maximizes the datarate on those and they are short enough not to fill it. If the final result after adding other videos etc is a full disk, Encore has probably transcoded using a lower datarate than the first videos.
I'm not sure what that means.
North America
Asia Pacific
