Smeal22
Metadata changed externally
Feb 21, 2013 12:03 PM
Tags: #problem #metadata #lr4 #lightroom4
I have just started to get this error.  I am using a Windows 7 machine & LR 4.3.
Here is my workflow:
Save images - JPGs only - on home server
Import images into LR using "Add" option
Go through the images in library for my initial pass
Mark images as rejected or certain # of stars
Immediately I get the overwrite error on the images I mark
I select the "overwrite settings" option
The error icon returns.
These images have not been opened in any other program since initial import or even before.
Any recommendations to resolve this error?
Sue
    Feb 21, 2013 4:48 PM   in reply to Smeal22
    I assume that by "overwrite error" you mean the "Metdata conflict warning" , and when you click on it you get this - see screen shot:
    This is an old bug in Lr. Do not be concerned about your images. Your images are absolutely fine because Lr saves every step you do instantly and automatically in the catalog.
    In addition to this saving to catalog there is an option (it's an option and not necessary for the function of Lr) to save the metadata to file. This is primarily for people who want / need to see the Lr edits in Adobe Bridge. Bridge cannot read the Lr catalog, but only the file. This makes it necessary to <save metadata to file>. The error message - it's actually not an error, it's just a hint - means that the data in the catalog and the data in the file are not completely identical. Since Lr always goes by its catalog - unless you do a <read metadata from file> your images are safe and sound.
    You can stop this message by doing this:
    Go >Edit >Catalog Settings >Metadata tab and uncheck the box <Automatically write changes to XMP>.
    After this Lr will stop saving metadata to file automatically and the error message will not appear.
    If you  want you still can save metadata to file, albeit manually. Either by going >Metadata >Save Metadata to File, or shortcut Ctrl / Cmd + S on your keyboard. You can batch save by selecting any number of images in the Grid View and hitting Ctrl / Cmd + S.
    Feb 22, 2013 8:19 AM   in reply to Smeal22
    I don't think that Bridge has anything to do with this. Bridge cannot change any settings in Lr.
    As said earlier this is a long-standing bug in Lr. One poster said that as they age age bugs become features .
    As far as I know there are only these two options:
    a) Either have <Automatically save changes to XMP> checked and live with the metadata warning.
    b) Or uncheck <Automatically save changes to XMP> and do a manual <save metadata to file>.
