johnhh39
Elements 11 photo orientatation
Feb 22, 2013 1:40 AM
Tags: #11
why does 11 show portrait photos as almost square, 9 did not. Even after cropping to 4x6 they still look as if sat on, -they print fine but display in Organiser and Editor as "sat on" How do I correct it?
    Feb 22, 2013 1:44 AM   in reply to johnhh39
    Could you please attach a snapshot showing the behavior between Organizer and Windows explorer?
    ~Andromeda
    Feb 22, 2013 2:39 AM   in reply to johnhh39
    Here is the snapshot showing comparision in displaying thumbnails in Windows explorer and in Elements Ortanizer:
    Both seems identical to me. Please elaborate your issue.
    ~Andromeda
  • 99jon
    Jan 6, 2010
    Feb 22, 2013 3:02 AM   in reply to johnhh39
    You do know you can push the zoom slider to the right to increase the size of thumbnails in Organizer?
    Feb 22, 2013 3:22 AM   in reply to johnhh39
    Please upload a snapshot of the Elements Organizer showing the incorrect dimensions.
    ~Andromeda
  • 99jon
    Jan 6, 2010
    Feb 22, 2013 3:23 AM   in reply to johnhh39
    It looks like it could be the camera settings as the aspect ratio is 1.33. Most DSLRs use 1.5 e.g for prints 6 x 4 inches.
    Both photos have a pixel dimension of 2736 x 3648
  • 99jon
    Jan 6, 2010
    Feb 22, 2013 3:37 AM   in reply to johnhh39
    It may be worth checking your monitor settings. Go to the control panel and check dpi scaling under Appearance or Display.
    It’s not uncommon to see a setting of 125% or higher to improve screen readability but PSE requires a dpi of 96 or 100%
    This often affects menus. Whilst the Editor Menu will appear at 120% to 149% the Organizer Menu (and the advanced button in downloader) won’t. Sometimes the mouse or tool cursors are distorted. Images could be affected
    Try a setting of 115% to 120% otherwise use 100%. A common display resolution, notably for notebooks/laptops, and netbooks is 1024 x 768 but PSE requires a screen height of 800 for full functionality. If your height resolution is out of the range 768 to 800 try experimenting with the slider/settings.
