How not to sort datagrid column on double click
Feb 22, 2013 8:01 AM
Tags: none (add) #flex-4.6Hello,
I am currently building an application containing a datagrid for data representation. I've created a custom datagridheader in order to add a input text for filtering the columns (see code below).
My goal is to hide the textinput, and then show it on a double click on the header. So i would like to know how to avoid the sort of this column each time i double click.?
<s:GridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx" resize="onColumnResize(event)" clipAndEnableScrolling="true" doubleClick="managefilterField(event)">
<fx:Declarations>
<!--- The default value of the <code>sortIndicator</code> property.
It must be an IFactory for an IVisualElement.
<p>This value is specified in a <code>fx:Declaration</code> block and can be overridden
by a declaration with <code>id="defaultSortIndicator"</code>
in an MXML subclass.</p>
@langversion 3.0
@playerversion Flash 10
@playerversion AIR 2.0
@productversion Flex 4.5
<fx:Component id="defaultSortIndicator">
<s:Path data="M 3.5 7.0 L 0.0 0.0 L 7.0 0.0 L 3.5 7.0" implements="spark.components.gridClasses.IGridVisualElement">
<fx:Script>
<![CDATA[
import spark.components.DataGrid;
import spark.components.Grid;
* @private
public function prepareGridVisualElement(grid:Grid, rowIndex:int, columnIndex:int):void
const dataGrid:DataGrid = grid.dataGrid;
if (!dataGrid)
return;
const color:uint = dataGrid.getStyle("symbolColor");
arrowFill1.color = color;
arrowFill2.color = color;
</fx:Script>
<s:fill>
<s:RadialGradient rotation="90" focalPointRatio="1">
<!--- @private -->
<s:GradientEntry id="arrowFill1" color="0" alpha="0.6" />
<!--- @private -->
<s:GradientEntry id="arrowFill2" color="0" alpha="0.8" />
</s:RadialGradient>
</s:fill>
</s:Path>
</fx:Component>
<!--- Displays the renderer's label property, which is set to the column's <code>headerText</code>.
It must be an instance of a <code>TextBase</code>, like <code>s:Label</code>.
<p>This visual element is added to the <code>labelDisplayGroup</code> by the renderer's
<code>prepare()</code> method. Any size/location constraints specified by the labelDisplay
define its location relative to the labelDisplayGroup.</p>
<p>This value is specified with a <code>fx:Declaration</code> and can be overridden
by a declaration with <code>id="labelDisplay"</code>
@langversion 3.0
<s:Label id="labelDisplay"
verticalCenter="1" left="0" right="0" top="0" bottom="0"
textAlign="start"
fontWeight="bold"
verticalAlign="middle"
maxDisplayedLines="1"
showTruncationTip="true" />
</fx:Declarations>
<fx:Script>
<![CDATA[
import net.awl.ismp.console.components.misc.FilterCriteria;
import net.awl.ismp.console.events.ColumnFilteredEvent;
import net.awl.ismp.console.events.ColumnResizedEvent;
import mx.events.ResizeEvent;
import spark.components.gridClasses.IGridVisualElement;
import mx.core.IVisualElement;
import spark.components.GridColumnHeaderGroup;
import spark.components.gridClasses.GridColumn;
import spark.primitives.supportClasses.GraphicElement;
// chrome color constants and variables
private static const DEFAULT_COLOR_VALUE:uint = 0xCC;
private static const DEFAULT_COLOR:uint = 0xCCCCCC;
private static const DEFAULT_SYMBOL_COLOR:uint = 0x000000;
private static var colorTransform:ColorTransform = new ColorTransform();
* @private
private function dispatchChangeEvent(type:String):void
if (hasEventListener(type))
dispatchEvent(new Event(type));
protected function onColumnResize(event:ResizeEvent):void
dispatchEvent(new ColumnResizedEvent(ColumnResizedEvent.COLUMNRESIZED_EVT,this.width,th is.column.columnIndex));
// maxDisplayedLines
private var _maxDisplayedLines:int = 1;
[Bindable("maxDisplayedLinesChanged")]
[Inspectable(minValue="-1")]
* The value of this property is used to initialize the
* <code>maxDisplayedLines</code> property of this renderer's
* <code>labelDisplay</code> element.
* @copy spark.components.supportClasses.TextBase#maxDisplayedLines
* @default 1
* @langversion 3.0
* @playerversion Flash 10
* @playerversion AIR 1.5
* @productversion Flex 4.5
public function get maxDisplayedLines():int
return _maxDisplayedLines;
override protected function stateChanged(oldState:String, newState:String, recursive:Boolean):void
trace("state changed from : "+oldState+" to "+newState);
super.stateChanged(oldState, newState, recursive);
* @private
public function set maxDisplayedLines(value:int):void
if (value == _maxDisplayedLines)
return;
_maxDisplayedLines = value;
if (labelDisplay)
labelDisplay.maxDisplayedLines = value;
invalidateSize();
invalidateDisplayList();
dispatchChangeEvent("maxDisplayedLinesChanged");
// sortIndicator
private var _sortIndicator:IFactory;
private var sortIndicatorInstance:IVisualElement;
[Bindable("sortIndicatorChanged")]
* A visual element that's displayed when the column is sorted.
* <p>The sortIndicator visual element is added to the <code>sortIndicatorGroup</code>
* by this renderer's <code>prepare()</code> method. Any size/location constraints
* specified by the sortIndicator define its location relative to the sortIndicatorGroup.</p>
* @default null
* @langversion 3.0
public function get sortIndicator():IFactory
return (_sortIndicator) ? _sortIndicator : defaultSortIndicator;
* @private
public function set sortIndicator(value:IFactory):void
trace("setSortIndicator");
if (_sortIndicator == value)
return;
_sortIndicator = value;
if (sortIndicatorInstance)
sortIndicatorGroup.includeInLayout = false;
sortIndicatorGroup.removeElement(sortIndicatorInstance);
sortIndicatorInstance = null;
dispatchChangeEvent("sortIndicatorChanged");
* @private
* Create and add the sortIndicator to the sortIndicatorGroup and the
* labelDisplay into the labelDisplayGroup.
override public function prepare(hasBeenRecycled:Boolean):void
trace("prepare !!");
super.prepare(hasBeenRecycled);
if (labelDisplay && labelDisplayGroup && (labelDisplay.parent != labelDisplayGroup))
labelDisplayGroup.removeAllElements();
labelDisplayGroup.addElement(labelDisplay);
trace(sortIndicator);
trace("sortIndicatorInstance : "+sortIndicatorInstance);
const column:GridColumn = this.column;
if (sortIndicator && column && column.grid && column.grid.dataGrid && column.grid.dataGrid.columnHeaderGroup)
const dataGrid:DataGrid = column.grid.dataGrid;
const columnHeaderGroup:GridColumnHeaderGroup = dataGrid.columnHeaderGroup;
if (columnHeaderGroup.isSortIndicatorVisible(column.columnIndex))
if (!sortIndicatorInstance)
sortIndicatorInstance = sortIndicator.newInstance();
sortIndicatorGroup.addElement(sortIndicatorInstance);
chromeColorChanged = true;
// Initialize sortIndicator
sortIndicatorInstance.visible = true;
const gridVisualElement:IGridVisualElement = sortIndicatorInstance as IGridVisualElement;
if (gridVisualElement)
gridVisualElement.prepareGridVisualElement(column.grid, -1, column.columnIndex);
sortIndicatorGroup.includeInLayout = true;
sortIndicatorGroup.scaleY = (column.sortDescending) ? 1 : -1;
else
private var chromeColorChanged:Boolean = false;
private var colorized:Boolean = false;
* @private
* Apply chromeColor style.
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
//trace("update display list");
// Apply chrome color
if (chromeColorChanged)
var chromeColor:uint = getStyle("chromeColor");
if (chromeColor != DEFAULT_COLOR || colorized)
colorTransform.redOffset = ((chromeColor & (0xFF << 16)) >> 16) - DEFAULT_COLOR_VALUE;
colorTransform.greenOffset = ((chromeColor & (0xFF << 8)) >> 8) - DEFAULT_COLOR_VALUE;
colorTransform.blueOffset = (chromeColor & 0xFF) - DEFAULT_COLOR_VALUE;
colorTransform.alphaMultiplier = alpha;
transform.colorTransform = colorTransform;
var exclusions:Array = [labelDisplay, sortIndicatorInstance];
// Apply inverse colorizing to exclusions
if (exclusions && exclusions.length > 0)
colorTransform.redOffset = -colorTransform.redOffset;
colorTransform.greenOffset = -colorTransform.greenOffset;
colorTransform.blueOffset = -colorTransform.blueOffset;
for (var i:int = 0; i < exclusions.length; i++)
var exclusionObject:Object = exclusions[i];
if (exclusionObject &&
(exclusionObject is DisplayObject ||
exclusionObject is GraphicElement))
colorTransform.alphaMultiplier = exclusionObject.alpha;
exclusionObject.transform.colorTransform = colorTransform;
colorized = true;
chromeColorChanged = false;
super.updateDisplayList(unscaledWidth, unscaledHeight);
* @private
override public function styleChanged(styleProp:String):void
var allStyles:Boolean = !styleProp || styleProp == "styleName";
super.styleChanged(styleProp);
if (allStyles || styleProp == "chromeColor")
protected function managefilterField(event:MouseEvent):void
trace("double click sortIndicator : "+this.sortIndicatorInstance);
this.filterInput.visible=!this.filterInput.visible;
this.filterInput.includeInLayout=this.filterInput.visible;
this.filterSpacer.visible=this.filterInput.visible;
this.filterSpacer.includeInLayout=this.filterInput.visible;
if(!this.filterInput.visible)
this.filterInput.text="";
dispatchEvent(new ColumnFilteredEvent(ColumnFilteredEvent.COLUMNFILTERED_EVT,new FilterCriteria(this.column.dataField,this.filterInput.text)));
this.filterInput.setStyle("borderColor",0xFF6319);
this.filterInput.setStyle("focusColor",0xFF6319);
//this.filterInput.setStyle(
protected function onTextInputSelection(event:MouseEvent):void
event.stopImmediatePropagation();
protected function onKeyUp(event:KeyboardEvent):void
if(event.charCode==Keyboard.ENTER)
stage.focus=null;
protected function onFocusOut(event:FocusEvent):void
this.filterInput.setStyle("borderColor",0x00ff00);
this.filterInput.setStyle("focusColor",0x70B2EE);
</fx:Script>
<s:states>
<s:State name="normal" />
<s:State name="hovered" />
<s:State name="down" />
</s:states>
<!-- layer 1: shadow -->
<!--- @private -->
<s:Rect id="shadow" left="-1" right="-1" top="-1" bottom="-1" radiusX="2">
<s:fill>
<s:LinearGradient rotation="90">
<s:GradientEntry color="0x000000"
color.down="0xFFFFFF"
alpha="0.01"
alpha.down="0" />
alpha="0.07"
alpha.down="0.5" />
</s:LinearGradient>
</s:fill>
</s:Rect>
<!-- layer 2: fill -->
<!--- @private -->
<s:Rect id="fill" left="0" right="0" top="0" bottom="0">
<s:fill>
<s:GradientEntry color="0xFFFFFF"
color.hovered="0xBBBDBD"
color.down="0xAAAAAA"
alpha="0.85" />
<s:GradientEntry color="0xD8D8D8"
color.hovered="0x9FA0A1"
color.down="0x929496"
alpha="0.85" />
</s:LinearGradient>
</s:fill>
</s:Rect>
<!-- layer 3: fill lowlight -->
<!--- @private -->
<s:Rect id="lowlight" left="0" right="0" top="0" bottom="0">
<s:fill>
<s:LinearGradient rotation="270">
<s:GradientEntry color="0x000000" ratio="0.0" alpha="0.0627" />
<s:GradientEntry color="0x000000" ratio="0.48" alpha="0.0099" />
<s:GradientEntry color="0x000000" ratio="0.48001" alpha="0" />
</s:LinearGradient>
</s:fill>
</s:Rect>
<!-- layer 4: fill highlight -->
<!--- @private -->
<s:Rect id="highlight" left="0" right="0" top="0" bottom="0">
<s:fill>
ratio="0.0"
alpha="0.33"
alpha.hovered="0.22"
alpha.down="0.12"/>
ratio="0.48"
alpha="0.33"
alpha.down="0.12" />
ratio="0.48001"
alpha="0" />
</s:LinearGradient>
</s:fill>
</s:Rect>
<!-- layer 5: highlight stroke (all states except down) -->
<!--- @private -->
<s:Rect id="highlightStroke" left="0" right="0" top="0" bottom="0" excludeFrom="down">
<s:stroke>
<s:LinearGradientStroke rotation="90" weight="1">
<s:GradientEntry color="0xFFFFFF" alpha.hovered="0.22" />
<s:GradientEntry color="0xD8D8D8" alpha.hovered="0.22" />
</s:LinearGradientStroke>
</s:stroke>
</s:Rect>
<!-- layer 6: highlight stroke (down state only) -->
<!--- @private -->
<s:Rect id="hldownstroke1" left="0" right="0" top="0" bottom="0" includeIn="down">
<s:stroke>
<s:GradientEntry color="0x000000" alpha="0.25" ratio="0.0" />
<s:GradientEntry color="0x000000" alpha="0.25" ratio="0.001" />
<s:GradientEntry color="0x000000" alpha="0.07" ratio="0.0011" />
<s:GradientEntry color="0x000000" alpha="0.07" ratio="0.965" />
<s:GradientEntry color="0x000000" alpha="0.00" ratio="0.9651" />
</s:stroke>
</s:Rect>
<!--- @private -->
<s:Rect id="hldownstroke2" left="1" right="1" top="1" bottom="1" includeIn="down">
<s:stroke>
<s:GradientEntry color="0x000000" alpha="0.09" ratio="0.0" />
<s:GradientEntry color="0x000000" alpha="0.00" ratio="0.0001" />
</s:stroke>
</s:Rect>
<!--<s:Rect id="fill" left="0" right="0" top="0" bottom="0">
<s:fill>
<s:GradientEntry color.normal="0xf9f9f9" color.hovered="0xfcfdfa"
color.down="0xdceac2" alpha="0.85" />
<s:GradientEntry color.normal="0xeaeaea" color.hovered="0xdceac2"
color.down="0xd2e1b5" alpha="0.85" />
</s:LinearGradient>
</s:fill>
</s:Rect>-->
<!--<s:VGroup left="7" right="7" top="5" bottom="5" gap="6" verticalAlign="middle">
<s:TextInput width="100%" />
<s:HGroup width="100%">
<s:Group id="labelDisplayGroup" width="100%" />
<s:Group id="sortIndicatorGroup" includeInLayout="false" />
</s:HGroup>
</s:VGroup>-->
<s:VGroup verticalAlign="middle" left="7" top="5" right="7" bottom="5" gap="2" >
<s:TextInput id="filterInput" width="100%" visible="false" includeInLayout="false" keyUp="onKeyUp(event)" focusOut="onFocusOut(event)" click="onTextInputSelection(event)"/>
<s:Spacer id="filterSpacer" visible="false" includeInLayout="false" height="5" />
<s:HGroup width="100%" height="100%" verticalAlign="middle">
</s:HGroup>
</s:VGroup>
</s:GridItemRenderer>
