Hi
I recently had a post in here about Layers and Fluid Grid,
I had said i was happy with the answer but turned out i am not able to have it work like it should.
So instead of continuing that post i made another one to further the conversation. A link to that first post here:
http://forums.adobe.com/message/5073511
I did what Nancy O suggested and placed her code in a style sheet and also the html:
#holder {
position:relative;
top: xxxpx;
left: xxxpx;
z-index1;
#button {
position:absolute;
top: xxx px;
left: xxxpx;
z-index: 10;
HTML
<div id="holder">
<div id="#button">your button here</div></div>
Thank you Nancy for that. I entered my values and must have done something to effect it how it connects to the parent.
Something i am missing? The app div is absolute and the parent is relative
Even with a fixed page of html5 with no fluid grid i tried to make an app div stay put in many browsers only to have it move around. I used an swf file video as the file size is much smaller for the web. I just want to put a simple rollover button over a flash video inside an app div and have it work or stay put in all browsers.
Thanks so much for the anticipated help .
I could not get it to work as the x- axis when page is grabbed and shrunk down the video moves but the app div rollover button stays fixed. .
The y- axis works fine.
I had also found this video which explains another way to do it and same thing. I followed this video to a T and nothing.
Without seeing a link to your page, it's impossible to give you anything but generic answers to your question.
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Button</title>
<style>
#holder {
position:relative;
width: 200px;
height: 200px;
margin: 45px auto;
background: maroon;
color:#FFF;
z-index:1;
button {
position:absolute;
top: 50%;
left: 50%;
z-index: 100;
</style>
</head>
<body>
<div id="holder">
Flash object code goes inside this container
<button id="button1">Button Text</button>
</div>
</body>
</html>
Nancy O.
Hi
I wanted to follow up.
Everything worked well with the holders and placement over the video. I ran it through the W3C and it gave me errors for using the z index for each holder. It said to only use a z index for the parent and not the child. I am also having overflow problems now and sort of at a standstill.
I have everything including the video inside of this container
<div class="c1">
Then i have the swf file
<object classid=xxx999xxxx width= "100"% hieght="720"px id=" flashID">
Then further down
</object>
Then all of the holders with rollover buttons seven total
closing with all inside of this "c1"
</div class="c1">
The rule for the "c1" :
The postioning in css is 100% for width and position is relative
The rule for the holders are:
box:
width and height : inherit
my margins are from -840 bottom on up to -600
more like this:
#holder5 {
postion: relative;
width: inherit;
height: inherit;
top -840
button6 {
position: absolute;
top: 680px;
positioning:
relative
width and height inherit
placement top -840
I know one of these is wrong or all and I'm sure an easier method is around?
Thanks so much if anyone can help
Dan
North America
Asia Pacific
