Hi all
Just wondering about the scratch disk size recommendations for Photoshop CS6 Extended, I've allocated 20GB on a separate hard drive for my scratch disk.
PC spec is
OS Hard Drive 128GB Crucial m4 mSATA 6Gb/s SSD
Intel Core i7 3770k processor
Geforce GTX 660 2GB DDR5 Graphics
16GB Ram
So is 20GB sufficent as a scratch disk, considering I've loads of RAM and Video RAM, had 52GB allocated and noticed I never used more than 1%
I assume it's OK
Cheers
Ged
Uh...Vram has ZERO to do with scratch...the ONLY aspect of scratch is the image resolution (size) and ram allocation. You seem not to undersand the relationships?
You prolly need a substantial multiplier in scratch size to your allocated ram...of you are allocating 10-12 GBs of ram to Photoshop you should figure PS will need 5-10X for scratch (even if it may not be used, it will be allocated).
20 GB is small...unless you have a scratch disk 2, 3 and 4, specificied...you can have up to 4 different scratch disks spec'ed.
With 16 GB installed, I would suggest 100-200BGs as the 1st scratch disk size..but a lot of that determination is dictated by file size and average number of layers, which you've not bothered to mention...are you working on small files with a ton of layers or large files with only a few–it makes a big difference...
North America
Asia Pacific
