SETTINGS: I animate and capture through Helium Frog (a capture program on the computer) and its saved as an AVI. My Camera is a Sony Handycam HC38E and it captures in 720x575, and is DV PAL. My project settings are DV Pal widescreen, frame size 720x576 (It's changed to look like widescreen through interpret footage) and is pretty much the same in Camcorder and Project.
PROBLEM: Allright, when I edit, I kind of do it in checkpoints, so if I get all the footage and effects done, I'll export it so it's one file to make it easier. But when I put it back into the project to add everything else in, there seems to be tension and nervousness at the top and bottom, where it shudders black and original footage. It looks terrible obviously. I think youtube gets rid of the shuddering, but nevertheless it is a great bother. Sometimes I can get ghosting as well, however I unfortunately go through the trouble of deleting the new frames. These are great pains to me and it drives my crazy. I try zooming in to remove it, however you can catch glimpses sometimes and I also miss out of all the footage which I obviously do not want. I've tried saving it in different formats but it is always the same result. Any help would be highly appreciated.
Thankyou
Yes I know. I have a firewire cable and I use it to capture on the family computer which is extremely slow. My Laptop doesn't have any firewire ports. In fact it only has three USB ports which really bugs me, and because it is a laptop I'm not sure If I can install any. I import it by USB Flash Drive. Helium Frog has a bunch of settings to animate with, whereas Elements would be a much weaker program to capture with, and I can't do it anyway not having firwire slots. Besides, THE BOBBING ONLY SHOWS UP WHEN I EXPORT THE VIDEO. So it must be a saving problem seeing as it only shows up then, but I've tried different saving formats and types! This is extremely annoying! I need help on how to fix it!
North America
Asia Pacific
