If the content in the DB contains characters that would
affect the generated html tag(s), then that is likely why it is not
working.
Try URLencoding the data before placing into the textarea and
see if it works. If it does, then you will have to scrub the data
before it is entered into the field each time; unless you are
missing something particular for your CMS editor.
I suspect that is what is happening, so I did try to
URLencode the data, and it populates, but it paces the URLencoded
value into the editor, when I want it to show the original html
inserted.
try using
<cftextarea ...
value="#jsStringformat(noteOBJ.getNoteContent())#"></cftexarea>
instead of
<cftextarea ...
>#jsStringformat(noteOBJ.getNoteContent())#</cftexarea>
I tried using the value attribute with jsstringformat and
with urlencoded value and they don't populate the editor with html.
jsstringformat populates with the slashes still in the text.
