I've been looking throught he forums for hours now, and everything is blurry so excuse me if I this is redundant.
Question I have is this:
I have a jpeg file that is, say, 4.80mb, according to the file info in Bridge. I open it in Photoshop.
If I try to Save or Save AS it the file size almost doubles, even without any changes to the file at all.
Why is this and is there a way to prevent it?
Thanks for your time
That does not compute. You are probably being misled by the "document size" in photoshop. That figure is not the file size but how much PS is reserving in memory to work on it. THe file size you save depends on the quality you save with in jpeg. If you use above 10 the file size can actually be larger than the original, but should not be double.
Exactly what are you doing?
The file size is 4.8 before I open it in CS6. That is verified from the properties info from Windows or Bridge.
Once I open it in Photoshop and tey to Save or Save As, without changing anything, as a jpeg file, the size doubles according to the info boh from Windows, Bridge or any other program.
You must be looking at something other than I see. I open a 1.6 meg jpeg file (bridge metadata) into PS. I then click Save As and click save when the window comes up. It then asks for the quality. At a setting of 10 the file size would be 1 meg, and even if I ramp it up to 12 the file size is 2.2 meg. (file size adjusts to the new quality setting but may take a second or two to compute)
When you say the size almost doubles where are you seeing these numbers?
Property tab of what?
Resoluton in ppi has nothing to do with save quality in jpeg. The quality changes depending on how many pixels you want to throw away to get a smaller file size.
Every time you save a jpeg it looses quality as it is being recompressed. You can not gain quality so just because the size is larger than the original does not mean it is a higher quality.
If you want to save with highest quality use TIFF or PSD, but the file sizes will be considerably larger.
Property tab of the file in say, Windows
We're getting further away from what I need to understand...
If the file started at 4.80 as a JPEG how do I save it just as it is, no adding or subtracting pixels?
Since I can not see what you see perhaps a screen shot of the 4.8 meg file opening as a 8 meg file would help. As it only makes sense that it will open as a 4.8 meg file.
If you are not getting what I am writing you need to do a web search for "saving a jpeg". Here is an excerpt from one.
But don't get too hung up on loss of quality, as if you save at quality 8 or above you will never see it unless your edit and resave may times. I save at quality 9.
If a JPEG image is opened, edited, and saved again it results in additional image degradation. It is very important to minimize the number of editing sessions between the initial and final version of a JPEG image. If you must perform editing functions in several sessions or in several different programs, you should use an image format that is not lossy (TIFF, BMP, PNG) for the intermediate editing sessions before saving the final version. Repeated saving within the same editing session won't introduce additional damage. It is only when the image is closed, re-opened, edited and saved again.
North America
Asia Pacific
