Easy question
Feb 23, 2013 5:27 PM
Thanks for looking in...
I was wondering how to cut a round out of a square. I have this coin I am cutting out and find that by only erasing the background and then importing into my editor leaves some residual artifacts.
I would like to cut it out as a 'stand alone' circle with out  a background whatsoever.
Please if you would in a bit of detail on the steps. How to cut out the dime from the closely cropped background?
Not sure if you can tell there is a  background as I did erase the background and save for "use on the web" with alpha BG. The background is evident in PS as a square that is as close to a round as possible. Which the sqare does show up in my video editing as a 'ghost artifact. Hence me wanting to crop that out as a round...
Thanks for your help on this one
NC
    Feb 23, 2013 6:31 PM   in reply to Netcommercial
    You can make a selection with the eleptical marque tool.  May take a few tries to see where you want it start to end up in correct spot.
    Check out this link for a few hints.  http://digital-photography-school.com/five-secrets-of-the-marquee-tool s-in-photoshop
    Feb 23, 2013 7:09 PM   in reply to Curt Y
    If you drag guides to the edges of the coin, you can then drag out the Elliptical Marquee from the intersetion of the guides, and it will be right in place.
    Feb 23, 2013 7:41 PM   in reply to Netcommercial
    Depends of end product.  If you want a coin with transparent backgound you can save selection with Ctrl C and click on File/new and paste.
    To save with transparent background you can use psd, tiff, or png.  Saving as jpeg will save it with a white background as it will not save layers.
    Feb 23, 2013 8:24 PM   in reply to Netcommercial
    You should contact the maker of the video editing software and ask for help to prevent the ghosts.
  • Noel Carboni
    Dec 23, 2006
    Feb 23, 2013 9:02 PM   in reply to Netcommercial
    FYI, in case it isn't clear...
    Every image known to modern man has a rectangular format, as far as I know.
    Your task is to create a rectangular image with transparent pixels around the outside of the coin and right up to the edges.  Several formats can carry transparency - PSD or PNG for example.
    Note that teh pixels that are right at the edge of the coin may end up partially transparent, to avoid jagged edges.
    -Noel
