How to import pdf with hyperlink and and maintain its hyperlink while exporting it as HTML?
Feb 24, 2013 1:18 AM
Tags: #indesign #import
We can import pdf in indesign either using plaacemultiplefile script or using place submenu  under file menu but both of them import pdf as graphic object and lost its all hyperlink. no doubt when i again export its as pdf than hyperlink are there as it is but when i export it as HTML,IDML or other format than than all hyperlink are lost so is there any way to maintain this if no than is there any way to write some new script utilities which will do the same .one solution i think is first convert pdf into docx and than import it as docx indesign import  it as text frame and maintain all hyperlink but in this process pdf file lost its some formating while converting it into docx .
