CS6 CS5.5 Export PDF stripping embedded profile
Feb 24, 2013 9:38 AM
I am trying to figure what's going on with Indesign File> Export PDF is stripping one of my embedded ICC profiles.
My test document has four tagged Photoshop RGB .jpg objects (sRGB, AdobeRGB, ProPhotoRGB, WhackedRGB).
Indesign working space RGB is sRGB.
OUTPUT SETTINGS:
GENERAL: Create Tagged PDF
COMPRESSION: Do not downsample; None
Yet Acrobat Object Inspector is reading the formerly tagged sRGB object as Device RGB.
It reads the other three tagged objects correctly.
It also does this in Indesign 5.5.
I want all to include ALL tagged source profiles as noted in my above screenshot setting.
My .indd and more screenshots and exported problem .pdf are ZIP HERE
Replies 1 2 3 Previous Next
    Feb 24, 2013 9:49 AM   in reply to gator soup
    Does it behave any differently if you use the PDF/X-4 setting?
    Feb 24, 2013 12:02 PM   in reply to gator soup
    If you place untagged content into ID it is presumed to be in the current working space -- you have to have some profile assumption for output. And you cannot have more than one output intent for a document, so if the tagged profile is a mismatch it is not already using the output intent.
    Seems to me the X-4 preset is behaving correctly.
    Feb 24, 2013 2:06 PM   in reply to gator soup
    OK, so what you are saying is you want your tagged images to retain the tags, and the untagged images to be assumed in the PDF to have the deviceRGB tag, is that correct? Or do you want them to have no tag at all? Seems to me the RIP needs something on which to base a conversion, and I'm not sure waht it would do with either Device RGB or no tag at all.
    We are starting to get outside my comfort zone here, but it sounds like you are not happy with PDF/X-4 because it seems to tag the untagged to make them behave the way they appear in the document in ID. I think I can accept the logic in that, but I can also understand that you might not and that you would want the numbers passed untagged so they would be presumed to be in whatever the default space used by the RIP might be, unpredictable as that is.
    Feb 24, 2013 3:18 PM   in reply to gator soup
    I don't work for Adobe, and I can't speak for them, but I would guess that some of the confusion here may come from a need to "simplify" the language used in the dialogs so it will fit.
    You might want to write this up as a bug: Adobe - Feature Request/Bug Report Form
    Feb 24, 2013 3:27 PM   in reply to gator soup
    I skimmed (not read thoroughly) your linked article. I think I understand where you are going, but I wonder how relevant this is in the real world for ID users. My presumption is that if you are building a file in ID you want it to output the way it looks on screen (at least I do), which means I do want untagged images to get tagged into the document working space on export so that the color renders as I intend.
    And, of course, there's always the caveat that one shouldn't forget to tag images withthe correct profile when they're saved to begin with, but that's a completely different discussion.
    Feb 25, 2013 8:49 AM   in reply to gator soup
    In this lengthy thread it finally turned out (detected by A.R.) that
    Photoshop PDF might be buggy:
    http://forums.adobe.com/thread/1141062?start=0&tstart=0
    Now we are talking about InDesign PDFs, and according to Gator
    these are buggy as well.
    Here, these exports are correct, but my apologies, done by CS2,
    which works for me flawlessly (*one exception) since many years.
    http://docs-hoffmann.de/colpdf27022008.pdf
    This doc shows on p.6 six images in these colorspaces:
    sRGB
    aRGB (AdobeRGB)
    ISO Coated
    Euroscale Coated
    Black Ink ISO Coated (Gray)
    Black Ink Euroscale Coated (Gray)
    Document space:
    sRGB
    ISO Coated v2 (ECI)
    *) Gray: not available
    Export to PDF:
    No color conversion
    Include all RGB and tagged source CMYK profiles
    PDF analysis shows:
    Images are based on ICC profiles  (not Device color) for
    sRGB
    aRGB
    ISO Coated
    Euroscale Coated
    *) Gray profiles are generally ignored by InDesign CS2
    'Embedded files none' doesn't mean that no profiles are embedded.
    The file size is about 3.5 MByte because of the embedded CMYK
    profiles (converting all images to ProPhoto reduces the file size to
    350kByte).
    By the way:
    Using several untagged RGB images for different color spaces in
    the same PDF is in my humble opinion not the least helpful -
    it's only confusing.
    Should the old version C2 work correctly, whereas new versions
    are buggy?
    Best regards --Gernot Hoffmann
  • Rob Day
    Oct 16, 2007
    Feb 25, 2013 5:14 PM   in reply to gator soup
    Output> PDF/X> "Output Intent Profile Name" seems to require a profile (Destination Space) -- my PDF images are already in their final Destination Spaces, and since those spaces are different and I don't want any changes whatsoever, this is very confusing
    The output intent is the profile of the press the job is intended for—or the profile that's expected to be used for converting RGB objects to CMYK on output. A different destination profile could be chosen at output, but there can only be one destination.
    If you want everything tagged why are you placing untagged images? When you export PDF/X-4, untagged images  get the document's profile because the X-4 standard requires every object have a tag. If you don't want your untagged images to get assigned document RGB you choose a different profile via Object>Image Color Settings...
  • Rob Day
    Oct 16, 2007
    Feb 25, 2013 7:36 PM   in reply to gator soup
    You could set your document profile to a profile you're not importing something like Monitor RGB. You're not including all profiles so native RGB objects get exported without a tag and are DeviceRGB no matter what the document's RGB assignment is.
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 4:56 AM   in reply to gator soup
    Here I'm assigning an RGB profile to my doc that isn't embedded in one of the placed files—my monitor profile in this case:
    When I export with Include Tagged Source Profiles, only the AdobeRGB and sRGB images keep their profiles. The native color is left untagged because I did not choose Include All Profiles.
    The native ID fill
    The image with no tag
    The sRGB image
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 4:46 AM   in reply to gator soup
    I'm still not following why you want untagged RGB to make it through to the PDF. Untagged images will eventually get an assignment over in Acrobat—it will be whatever the Acrobat CM RGB Working Space happens to be at output
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 7:53 AM   in reply to gator soup
    Exporting untagged RGB is not a problem.
    I get the four untagged .jpgs Exported into .pdf just fine (screen shot in my original post).
    Over in Acrobat your untagged images will get Acrobat's working space, so if it's set to sRGB in the color management prefs, the untagged images get assigned sRGB.
    So, what's the problem with setting the ID document RGB assignment to sRGB and exporting PDF/X-4? The result will be the same, in both cases the untagged files get assigned sRGB. The problem with letting them go through without a profile is the assignment in Acrobat will be arbitrary, it will be whatever the pref happens to be set at.
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 9:42 AM   in reply to gator soup
    Yes, exactly -- Acrobat will will assume sRGB for Source>Monitor and Source>Destination color conversions -- I get that
    No, Acrobat will assign whatever happens to be the current Working RGB space—Preferences>Color Management>RGB, which could be anything. The other CS applications work the same way. If you open an untagged Photoshop file it gets assigned whatever happens to be the current Color Setting's Working Space
    PDF/X-4 appears to require a destination profile and tags all four flavors of my untagged RGB with that profile
    It's requiring everything have source profiles, the destination is chosen at output. What is the correct source profile for your untagged images?
    And assigning the wrong profile (mistagging objects) to try and work around this problem seems like it would open a severely complicated bucket of worms to sort out.
    In my example the native objects are exporting untagged. They don't get the assigned document RGB profile because we are not choosing Include All Profiles. Untagged native RGB objects would present a problem at output, but so would your untagged RGB images.
    Feb 26, 2013 9:46 AM   in reply to Rob Day
    Referring to post #20:
    Rob,
    IMO, your statement
    is correct, if you mean by Acrobat  reading the PDF. I won't be correct, if you mean
    Export to PDF - just to clarify this.
    This doc
    http://docs-hoffmann.de/a3gencolorhigh.pdf
    contains on purpose many untagged color graphics. The source color space is always
    clearly indicated on each page. For instance p.6: ProPhotoRGB.
    Open this doc in Photoshop and assign ProPhotoRGB - the appearance will be correct
    and the measurable RGB numbers (Info) are indeed that of the source - ProPhotoRGB,
    as printed in the patches.
    This says, like all other tests:
    InDesign's Export to PDF leaves all images untouched if exported in mode
    No Color Conversion
    The claim, that Export to PDF strips profiles from tagged images needs to be proved,
    based on the complete workflow, mainly by the complete folder of sources. Perhaps
    the respective sRGB image was saved without profile (untagged)?
    I don't believe that Export to PDF had been modified since version CS2 (mine) so,
    that it is now buggy. This could be easily proved.
    But please, by two different workflows, resulting in two different threads:
    a) the case of untagged images
    b) the case of tagged images
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 10:07 AM   in reply to gator soup
    Here's the effect of Acrobat's working space on untagged objects.
    If I set working RGB to sRGB my untagged example matches the tagged sRGB imageScreen shot 2013-02-26 at 12.48.40 PM.png
    If I change the working space to ProPhoto the previews of the untagged RGB objects change accordingly:
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 10:03 AM   in reply to G.Hoffmann
    When you place an image  with a profile that matches the ID document's profile, the assignment is considered document RGB. To include the document RGB profile on export you have to choose Include All Profiles (i.e., PDF/X-4).
    You are right there are no conversions happening here, it's just a question of what profiles get exported with the PDF. There could be an argument for exporting CMYK untagged (you want to protect certain CMYK mixes), but not RGB.
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 1:20 PM   in reply to gator soup
    Acrobat "Assumes" the current working space for tagged and untagged objects
    No, only untagged objects get assigned the Working Space, which Preflight and Output Preview label as DeviceRGB.
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 1:55 PM   in reply to gator soup
    how can Acrobat be any different
    It isn't, that's my point.
    Untagged RGB images are a problem in any of the applications because the assignment will be arbitrary. It will be sRGB on your machine because your working space happens to be sRGB, on mine it will be AdobeRGB—the preview will change between our two machines.
  • Rob Day
    Oct 16, 2007
    Feb 26, 2013 3:14 PM   in reply to gator soup
    Ok, so why would you want to place untagged RGB and let them export that way? If your Acrobat working space is the correct source profile why not assign it in ID?
  • Rob Day
    Oct 16, 2007
    Feb 27, 2013 8:10 AM   in reply to gator soup
    I get "DeviceRGB" -- the ICC profile has been stripped.
    I do not. That's because my CM RGB Policy is set to Preserve Embedded and my Working RGB space is AdobeRGB so AdobeRGB gets assigned to the new document.
    See my #25.
  • Rob Day
    Oct 16, 2007
    Feb 27, 2013 9:31 AM   in reply to gator soup
    your working space should be irrelevent with tagged images if you are "preserving embedded profiles" (the Export settings indicate my source should Export unaltered)
    With Preserve Embedded as the RGB policy my new document gets assigned AdobeRGB—the assigned Document RGB profile (not the RGB working space) color manages native and untagged RGB objects. In this case a placed AdobeRGB image would be considered document RGB, so to include its profile on export I have to export the document RGB profile via Include All Profiles.
1 2 3 Previous Next
Actions
